grey matter
I was wondering if I should get my new Jetta rustproofed. I know they warranty the body for 12 years LOL. They have to drill holes for the spray, but will that void the warranty? Anybody come across this issue? Thanks
I have had mine Krowned also...Good insurance in our Canadian climate, take care.I just got mine Krowned and they state in writing it doesn't void your warranty....well worth it in our climate.
How long will you keep your VW? Look at older VW cars I never seen them with holes endless they are really old. Crown needs to be performed once every year and cost 120 a year. In ten years that's 1200 bucks. Now if you keep your car that long it is still under a VW warranty too. I spoke to a respected crown rust proofing owner who also has his own body shop that specializes in older cars restorations. He said VW factory is one of the best at protecting from rust and crown spray job is not going to help much if at all.I plan on getting mine Krowned as well. Drove 50 miles to Sarnia, ON and had it done on my pickup truck. Cheap insurance. Plus, I think the VW rust warrenty only covers "perforation" or rust HOLES. I do not want to get to the point of having holes in my car to test the VW warrenty. I will be getting my new 2013 Jetta done next spring.
The car is already rust proofed from the factory. No reason to do a thing else for rust proofing it. Wash it, dry it, wax it and it will last a long time.What is this crowning cost difference when compared to rust proofing?
I would and I will, just as I have rustproofed all previous cars.I was wondering if I should get my new Jetta rustproofed.
Yes, for perforation from the inside out. Chances are that won't happen and by the time the warranty expires, rust will already have started.I know they warranty the body for 12 years
Normally yes, if you just let them loose at the car. My car does not have a single hole drilled. There are plenty of rubber capped access holes under the car. I pop those off and after the spraying process, reinsert the caps.They have to drill holes for the spray, but will that void the warranty?
Krown is not a rustproofing product like that black tar they used to spray on ages ago. You want a rustproofing product that never dries or hardens. You want one that creeps all the time. Those wax-oil products aren't great either.What is this crowning cost difference when compared to rust proofing?
I've never rust proffed any of my vw's in the last 15 yrs.The car is already rust proofed from the factory. No reason to do a thing else for rust proofing it. Wash it, dry it, wax it and it will last a long time.
Thanks for the info.993er said:Krown is not a rustproofing product like that black tar they used to spray on ages ago. You want a rustproofing product that never dries or hardens. You want one that creeps all the time. Those wax-oil products aren't great either.
Krown is usually applied once a year, but you can get away by applying it the first three years and then every second year thereafter.
Some have had no issues and others that I know have had rust start at the holes. Who knows why.Drilling holes is a good idea, imo. Mine were drilled 8 years ago and there is no rust or any issues with them.
I don't know why. Try another Krown dealer.Who is your supplier? I tried a couple Krown dealers and they wouldn't sell it to me in anything other than cans...
Its not one of those modules with a flashing LED to give you hope, is it?You might want to investigate the electronic anti-rust modules.
The vast majority of cars nowadays do not rust in six or even eight years. They are well protected. I too had a paint chip form the first year to the fifteenth year with no rust...if it does not break through to bare metal, the zinc primer will prevent rusting.The Focus is going into it's 6th winter in southern Ontario, where the cars swim in salt water for 4 to 5 months of the year.
I used to on the Honda CR-V. It took well under 4 minutes to remove each door panel and it was so well thought out, there was no chance of breaking anything.And don't have to remove the door panels and potentially create new rattles using this method.
I miss the CR-V when it comes to that. All I did was drive it up on a couple of pieces of 2 x 12 and I had plenty of room under it. I sprayed the Jetta curbside; no way I was messing up my spotless garage.Used ramps and a couple jack stands to get the car high enough so I could crawl around under it.
That's funny, I actually built a new house 2 years ago and am renting my old house to one of my best friends. So I left all my tools setup there, keeps the mess outa the new houseI used to on the Honda CR-V. It took well under 4 minutes to remove each door panel and it was so well thought out, there was no chance of breaking anything.
A few days ago, I watched a YouTube video of a door panel being removed on a Mk6 Jetta. After viewing that, the panels are staying on.
What spray gun applicator are you using?
