Mr. Furious
As I mentioned in another thread, I finally reached my breaking point with the RNS-510 and decided that it was time to replace it with something that didn't make me want to pull my hair out.
Well, as of today, my RNS-510 is sitting on my coffee table and something that doesn't feel like it was designed in 1984 is in its place.
I had originally decided on the Alpine INE-W957HD, but the installer told me that particular line was experiencing some lockup/crash problems, and though they were working on it, it might be better to go with something else. He recommended Pioneer.
I opted for the Pioneer AVIC-8000NEX. With that out of the way, I set about figuring out how to connect all the OEM stuff that I could. Thanks to JM Popaleetus and some research of my own, I managed to get it right.
Specifically, I wanted to use the factory GPS antenna, SiriusXM antenna, AM/FM antenna, and rear view camera.
The real bear was the rear view camera. The VW RVC is an RGB camera with a proprietary 26-pin connector. Most (all?) aftermarket head units take a simple composite connection. Solving this issue ended up being more fraught than I expected it to be.
I found this adapter at aliexpress.com. At only $36 (plus about $5 shipping), it was a bargain, and it was literally the only one I could find†.
The bad news is that adapter is not available right now. Hopefully, it's just out of stock and not discontinued.
At JM's suggestion, I turned to enfig.com for the other adapters. Christian at Enfig was very helpful. The specific adapters that I purchased were:
Finally, in order to retain steering wheel controls, I got the PAC RP4-VW11. The disappointing there here is that while steering wheel controls were retained, most of the MFD integration was not. It's not a huge deal, but it would've been nice to have.
Oh, if you want SiriusXM, you have to buy a tuner.
The installation went fine. The RVC works like a champ, as does everything else. Yay for modern technology!
†There was a similar product on navlinkz.de, but that site didn't want to cooperate
- SiriusXM Antenna Adapter
- GPS Antenna Adapter (this appears to be Pioneer-specific, but there are adapters for other brands on their site)
- AM/FM Antenna Adapter
