98mkiv
So my 2010 Jetta Sedan is throwing a p0401 code every so often. It comes on for a few hundred miles, then at a restart may go off for a few hundred, then come on again during driving. I've pulled the EGR Valve (between the TB and the head) and cleaned it, it was a little gunky but not too bad. CEL came back on and has behaved with the same intermittent behavior.
So I thought I was pretty clever pulling and cleaning the EGR, but no dice.... anyone have some suggestions. If you can explain how the EGR works and the components that would be great too. Is there a filter?
Thanks!
Thanks!
