TDI 3.0 - timing chain tensioner covered under extended warranty?
2playok
Milwaukee, WI
2010 VW Touareg 3.0l TDI
2010 Touareg TDI with 118k, timing chain and/or tensioner failure - metal shavings. $8k minimum to fix and $12k for a new VW engine. Only place suggesting to fix is VW, the rest will not even touch it.
The cost of a used engine is not bad ($3-5k), but the 30 hours to remove and replace adds up to over $5k in just labor. There is also 0 warranty on the labor if your replacement engine doesn't work.
holeintheice
Minnesota
2015 TDI SW
Leave the motor in and pull the transmission. Can do it that way. I had a rattle on my 14. Said there was a new "updated" tensioner. I complained enough and they replaced the arms, guides and chain too. Under warranty. Still had to pay extra for the HPFP ones though. Extra $700.
