I posted about this a couple of weeks ago about replacing the thermostat, but got no clear answer. i was wondering if sombody could tell me how to and where it is located i would appreciate it very much. I have a 98 TDI
Follow the lower radiator hose to the water pump assembly. Where the hose connnects to the water pump there are two bolts that attach a housing to the pump. Unbolt that and there's the thermostat.
