CharlieTDI
I have an intermittent engine start problem when the engine is cold. Car is a Mk4 Golf TDI (ATD Engine).
What happens is the engine starts but instantly revs high. On starting, the revs will immediately go to anything between 1,200 and 2,000 RPM and then drop slowly. The revs will drop to the normal 900RPM idle – generally within a few seconds, the longest I have seen it take is 15 seconds or so. Sometimes the revs will increase by 100-200 for a few seconds and drop again (similar to gently pressing the accelerator). Generally after 30 seconds to a minute of running, the revs maintain a (normal) steady 900 RPM idle.
Other things I know are as follows:
1. Car has been fine all summer but the temperatures here in the UK are beginning to drop and when this happened, this issue arose (albeit intermittent). This may however be coincidence.
2. Only happens when the engine is cold. When starting when hot or warm it's fine.
3. The real clue it is going to rev high on starting is that the glow plug light does not extinguish when turning on the ignition (glow plug pre-heat). The light normally goes out after approximately 3-5 seconds. If the glow plug light goes out, the car starts as it should. If the light stays on I see this problem, but when the engine starts the glow plug light goes out.
4. There is no smoke or soot on starting.
5. The car's performance and MPG are as expected.
I'm hoping this has been seen before or is a known issue.
Any advice or pointers to what's at fault would be great.
