toot77
- Joined
- Oct 31, 1999
- Location
- Michigan, USA
- TDI
- 2000 Jetta TDI auto (180K miles), & 2013 Jetta TDI (50K miles and sadly returned)
I have learned that I am not able to open the trunk lid with the key on my 2000 Jetta. It opens fine with the door switch and the fobs so I imagine the problem is corrosion in the key lock cylinder thanks to the road salt over the years. I had the same problem with the key cylinder in the driver’s door and was able to disassemble, clean, and reassemble it last fall while replacing the door latch module and did get the door lock working again. Can anyone tell me how difficult it is, and possibly a procedure to remove and disassemble the trunk lid key cylinder from a 2000 Jetta?
thanks
thanks
