Old May 14th, 2017, 06:14   #1
C-lindsay@sympatico.ca
Default 2105 Golf shutter/vibration at 1100 RPM
Just picked up Golf 2015 TDI. New one from dealer. Just released. When driving notice a shutter/vibration at 1100 RPM only. Otherwise fine. I have not spoken to dealer yet. Wondered if anybody has any ideas?
C-lindsay@sympatico.ca is offline   Reply With Quote
Old May 14th, 2017, 06:56   #2
The Tortoise
I notice a slight vibration at around that rpm when accelerating in 6th. I just figured it was the result of putting load through a low revving motor.
Sent from my XT1097 using Tapatalk
The Tortoise is offline   Reply With Quote
Old May 14th, 2017, 08:14   #3
Going to dealer with minor problem with interior. Will see what they say.
Old May 14th, 2017, 08:15   #4
Going to dealer to check it out.
Old May 14th, 2017, 08:36   #5
viking427
TDI(s): VW
Downshift !
Motoring happiness is a clutch pedal and no spark plugs.
viking427 is offline   Reply With Quote
Old May 14th, 2017, 12:00   #6
jason_
The harmonics diesels produce @ the crank and get carried through the drive train, what would you expect at such low rpm?
Those aren't vibrations, it's ignition and torque!
Sent from my One using Tapatalk
jason_ is offline   Reply With Quote
Old May 14th, 2017, 16:25   #7
turbobrick240
turbobrick240's Avatar
1100 rpm is way too low in any gear other than first. Trying to accelerate from 1100 rpm in sixth gear is lugging the engine to a ridiculous extent- puts tremendous unneeded strain and wear on the engine.
Old May 14th, 2017, 16:59   #8
adjat84th
adjat84th's Avatar
Fuel Economy: ~50 in mixed driving
Assuming a manual transmission here, the suggested gear displayed on the MFD is programmed with efficiency in mind only. In our wagon, I frequently find the driver (wife) slowing down in gear and not downshifting when needing to accelerate again thus causing a complaint that the car is slow....smh! I can only imagine the life expectancy of the DMF being shortened as well if driving this way frequently.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, DC stage 3 w/ SMF, Fluidampr
adjat84th is offline   Reply With Quote
Old May 14th, 2017, 22:06   #9
Grigg3
I've never had a car that told me when to shift until now. It's kind of neat, and seems to know its stuff at least with good mileage as the goal, so how soon to get into a higher gear.
Pretty terrible on suggesting down shifts though, basically at an idle in whatever gear you should then down shift... that's fine for coming to a complete stop. In real life you usually need to shift before then.
I'm trying it's suggestions for up shifts to see what mileage It'll get, and trying to drive sensibility. Downshifts though are still up to me and the driving situation at the moment.
05 Jetta wagon, 15 Golf wagon
Grigg3 is offline   Reply With Quote
Old May 15th, 2017, 11:50   #10
turbobrick240
I'd just ignore the shift indicator and keep the rpm over 1600 when accelerating or on the throttle. The fuel mileage on my mk6 would suffer if I shifted when it indicates. Maybe it would be ok if I lived in Iowa or someplace unusually flat.
Old May 19th, 2017, 10:01   #11
TDI BR
TDI BR's Avatar
Fuel Economy: 45-50mpg
My flywheel would shutter sometimes in high gear, low rpm. But I also had mine deleted and tuned. Easy way to avoid it is to just down shift. No need to stomp it at low rpm. Never listen to the shift indicator. Mine would tell me to be in 6th gear at 46mph. There's no way I'd shift that high unless I was going 55+( and definitely not while going uphill).
2015 Golf TDI SE 6 M/T
The first tuned and deleted mk7
Malone stage 2
EGR/DPF/Adblue delete
GDM custom 2.5" resonated straight pipe
TDI BR is offline   Reply With Quote
Old May 19th, 2017, 11:51   #12
bmwM5power
bmwM5power's Avatar
do you hear the rattle when you press/ release the clutch at idle? or better yet press the clutch, rev it up and then release the clutch, mine sometimes has a slight rattle when I do this
bmwM5power is online now   Reply With Quote
Old May 20th, 2017, 08:19   #13
jason_
When I loaded the clutch a bit i would hear input shift clatter in the gearbox. It can be conformed by letting the clutch out a fuzz in neutral, when the noise starts, try pushing it into gear to put rotation resistance on the input shaft from synchronizers
If it gets quieter it's just gear lash clatter, and the traditional harmonics of diesel ignition is getting carried through the shafts.
Old May 20th, 2017, 13:56   #14
bmwM5power
bmwM5power's Avatar
the thing is i bought 2 gsw manuals, one clatters the other is silky smooth, no clatter or difference with clutch in or out
Old May 21st, 2017, 18:05   #15
Guys, this is an automatic transmission. Went to dealer and mechanic indicated something to do with power steering. Makes no sense to me. Taking to my friend who is mechanic for another opinion.
ALH starts but will not rev past 1100 RPM leusgs VW MKIV-A4 TDIs (VE and PD) 69 June 13th, 2014 11:46
2011 Golf TDI - Funny sound when 1100 - 1200 RPM reneeasteria VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 3 February 19th, 2014 20:48
Vibration between 1100-1800RPM's apples12 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 9 December 22nd, 2013 13:59
01 w/ VF dogbone and heavy vibration under 1100 Crispy222 VW MKIV-A4 TDIs (VE and PD) 2 April 8th, 2013 12:22
idle at 1100 rpm? wakeboarder_shawn TDI 101 3 June 5th, 2006 09:11
Page generated in 0.15373 seconds with 13 queries
[Output: 121.11 Kb. compressed to 100.60 Kb. by saving 20.51 Kb. (16.94%)]
