Baratis
Posted about looking for a new wiring harness a while back without needing one urgently. Few months ago I got a CTS code. Replaced connector and sensor which didn't fix it. Then, I had an MAF code. I replaced the sensor, which didn't fix it. I then searched online for a new connector. Ordered one and it took weeks to arrive. Replaced the connector and it was still down on power, so I plugged in vag com again. No response to it. I tried my bluetooth code reader. Again, nothing. Went to a known good electrical shop in the area and dropped off the car. Got a call a bit later saying they have no wiring schematics and could not find any, and it would likely be very expensive to pull apart and try to diagnose without one. They recommended I call a dealer and ask if they have the wiring diagram. I called 3 and none of them did. So I ordered an all new harness that was stated to fit my car. It did not. I ordered another one that was stated to also fit my car. It also did not fit. So, to sum it up, no replacement wiring for this car is available, no complete wiring diagrams exist, and no one knows how the electrical system on this car works. It seems at this point the car is dead in the water which I am livid about as I have worked the past 2 years getting the car mechanically perfect. I'm pissed off enough to send the damn thing to a crusher out of spite and buy a 50-year-old Beetle I can actually get any part I need for it.
