sober_lime
I have a 2002 New Beetle that has developed an issue. After driving for a good 20 minutes or so, it will sometimes have almost no power. it will also sometimes do it in a manner that makes the car jerk repeatedly at speed. as if power is coming and going. I only know about the exhaust leak because i saw a column of sooty exhaust come out from behind the engine when i started it, checking this problem. I pinched off the vacuum tube controlling the egr to see what that did, power loss happens less often, it is better but still not fixed. I do not have a vagcom, i only had a generic scanner. it showed me 12g/s at idle for the maf, 24g/s and it didn't really go higher than that as i revved it. I converted that to mg/stroke and it's "in spec" at idle, but the mg/stroke actually drops at higher rpm's. When it loses power while driving it will struggle to go above 3000rpm, and it doesn't even try to down shift. it will always redline in neutral though. This car also has a P0740, and has had it for awhile now.
What exactly are POSSIBLE causes? My theories are stuck vanes, bad maf? (cleaned it), clogged intake? (i was told the egr had been changed before we got it, it used to act like the "turbo doesn't spool", which sounds similar to this.), could a vacuum leak cause it? If the turbo was not always responding, and that is the problem, would there be a code for lack of boost?
