jman_mn
- Joined
- May 16, 2002
- Location
- Central MN
Hi Guys,
I was just changing the oil on my '99 A4 Jetta (90K miles), when much to my chagrin I discovered the main seal leaking. The oil is only down maybe 1/2 quart (still above low marker), so no damage to the guts. I called my dealer to check if this was under warranty, but the service dept was already gone (they leave @2 on Sat.). I talked to a sales guy who basically said that if it is a lubricated part (it is) in the engine or tranny (again yes!), then it is covered by the drivetrain warranty. I have to call the service dept on Monday morning, but I wanted to bounce this off of you guys to make sure I know the deal before I talk to the service department and they (maybe) try to screw with me.
As far as you guys know, is the main seal covered under the 100K drivetrain warranty?
Thanks in advance for the info!
-jman
-jman
