Old August 13th, 2019, 18:46   #1
Ramp Rat
Ramp Rat's Avatar
Default 06 BRM DMF life expectancy?
Iím planning on changing out my DMF on my 06 Jetta BRM with auto. Iíve searched on IDParts and found two offered. One is an OEM and the other is from LUK (which is much cheaper). Does anyone have experience with either of these flywheels. Will one last longer than the other? Are there any side effects from either? OR, should I look somewhere else?
Thanks for the help.
Steve.
Ramp Rat is offline   Reply With Quote
Old August 14th, 2019, 11:20   #2
p930man
Fuel Economy: jetta 40-50
We just replaced the DMF in our 06, we went with the LUK. the job was a bit of a problem. Mainly getting the correct parts. We replaced the rear main seal, and this must be installed properly, the crank shaft sensor must be positioned correctly, they make a special tool for installation of the seal. We did not use the tool, probably should have. This may be part of our issue now with starting.
p930man is offline   Reply With Quote
Old August 14th, 2019, 12:47   #3
crazyrunner33
crazyrunner33's Avatar
The LUK DSG flywheel for the BRM is the OEM flywheel. If you want, you can spend more for the version with the VW logo stamped on it.
https://www.idparts.com/dsg-flywheel...cg-p-1956.html
I would expect 100k-250k out of the newer updated flywheel. Revisions have been made since the original.
'06 Jetta DSG: GTB1749VC, PD150 injectors, Malone tune, and some other stuff and things
'97 Cummins: It looks stock, does that count?
crazyrunner33 is offline   Reply With Quote
Anyone know the approx. weight of a DMF in an '06 Jetta TDi w/ 1.9L BRM? redneckincanada TDI Power Enhancements 7 February 22nd, 2014 11:49
Normal Life Expectancy BRM Glow Plugs nutdriver VW MKV-A5 Golf/Jettas 8 December 8th, 2013 16:49
06 BRM turbo life? xracerbob VW MKV-A5 Golf/Jettas 9 August 4th, 2012 11:16
06 Jetta BRM DSG DMF failure, broken bellhousing! Losha VW MKV-A5 Golf/Jettas 9 June 18th, 2012 20:16
DMF failure and replacement, 06 manual BRM sptsailing VW MKV-A5 Golf/Jettas 4 June 23rd, 2011 09:43
Page generated in 0.16283 seconds with 13 queries
[Output: 57.82 Kb. compressed to 52.50 Kb. by saving 5.32 Kb. (9.19%)]
