2015 Golf Sportwagen with 34K. Manual trans, S trim. Long list of problems. Worst is likely damage to wiring by rodents. Interior lights do not work and the radio is locked (muted) by "Component Protection is Active." VW dealer wants to peel off the dash and investigate at 120/hr. Oil had not been changed, floor mats, cargo cover, skid plate stripped out, washer nozzles clogged, A/c probably doesn't work (hard to tell as it's cold here), Wheels are from an older Jetta with bad tires. Runs, drives well. Have changed oil/filter and fuel filter, new aluminum skid plate, found the cargo cover on Ebay for $167 shipped, new Continental tires, new tdi mats. VAG denies all responsibility for storage problems and for selling the car at auction in this condition saying dealers can do what they want. Going to need some sort of warrantee on the non-engine/exhaust stuff covered by VW.
Update: Turns out the washer nozzles were disconnected from the fluid feed tubes. 5 min. fix. Nest above infotainment module in glove box cleaned out and all wiring is undamaged (took VW dealer 3 hours to figure out non-original module was the cause of the CP code) . Interior lights not working because someone pulled out all the bulbs! Info module not original to the car so that explains the Component Protection code. Dealer installing new module. New OEM monster mats and original manual found on Ebay. When I get the car back will be flushing the brake fluid and it will finally be what I thought I was buying, a just serviced, no issues tdi GSW manual 6-speed.
