Old August 1st, 2020, 06:31   #16
timeline
timeline's Avatar
Fuel Economy: 44-48
Thanks, Is there a way to tell which I have without pulling it apart?
2002 Jetta wagon TDI
timeline is offline   Reply With Quote
Old August 1st, 2020, 07:12   #17
Dannyboy
TDI(s): 2014
Removing the starter will give you access , should be able move inner section separately from starter ring section
Dannyboy is offline   Reply With Quote
Old August 1st, 2020, 07:22   #18
csstevej
How long have you had the car ?
2001 golf auto to 5 speed manual swap,G60/VR6 clutch setup,coolant migration mod.
csstevej is offline   Reply With Quote
Old August 1st, 2020, 07:56   #19
If the clutch and flywheel is original to the car it's a DMF.
And I wouldn't call it a failure point, DMFs have a service life. 200K miles is pretty good. Some last longer, some don't. The DMFs in early DSG transmissions had shorter lives, but they're better now.
If the OP's car has 220K on it, odds are any clutch kit he installs will last the remainder of the car's life. I like the way DMFs perform in these cars, but there honestly isn't a big difference. Most SMF kits sold these days have quiet hubs on the disc so there's no rattle people used to experience in the G60/VR6 setups.
2002 Jetta wagon, 412K, RC3+; 1993 Mercedes-Benz 300D 2.5, 199K; 1997 Passat, 289K; '99.5 Golf, 262K; 2011 335d, 64K; 2015 Golf Sportwagen, 14K. Principal, http://www.idparts.com
Old August 1st, 2020, 08:27   #20
Vince Waldon
Vince Waldon's Avatar
A reasonably accurate Youtube vid on some of the differences between dual mass and single mass flywheels:
https://www.youtube.com/watch?v=1FDuK8UoVa0
Canadian Grizzly's excellent low-power/limp mode troubleshooting guide
VW's TSB for scientifically tracking down parasitic current drains
Vince Waldon is online now   Reply With Quote
Old August 1st, 2020, 10:14   #21
Dannyboy
TDI(s): 2014
My 2014 with 50k miles DMF is starting to knock in cold weather so I disagree that it was just early DSGs. It's been pampered all its life too.
I do agree with getting a replacement DMF, just make sure it's an updated one as the earlier OEM Sachs ones are more likely to fail.
Old August 1st, 2020, 10:42   #22
timeline
timeline's Avatar
Fuel Economy: 44-48
Had the car since '14. Jason put a new engine in a used wagon i bought from one of his new clients who blew up the engine getting bad service before he met Jason. Jason had another client that crashed his jetta and sold him the engine out of it. I paid Jason to merge the two. The engine is 120 k less miles on it. Not sure if he put the trans in as well. Never asked him. Thanks for that info Danny and Vince. Cool.
Throw out bearing SPOOLIN_TDI VW MKIV-A4 TDIs (VE and PD) 6 March 21st, 2019 11:35
Replaced throw out bearing - need help!! playback TDI 101 12 January 15th, 2015 09:04
Throw out bearing repair in Milton??? LukesTDI Ontario 8 November 1st, 2012 08:04
Throw Out Bearing? Jeepmb TDI 101 1 September 6th, 2008 19:34
throw out bearing ? chaser55 VW MKIV-A4 TDIs (VE and PD) 3 December 9th, 2000 21:45
Page generated in 0.13131 seconds with 13 queries
[Output: 82.21 Kb. compressed to 71.50 Kb. by saving 10.71 Kb. (13.03%)]
