Here is some parts i have for sale:
OEM PD lift pump with parts to build bypass if pump fails (as per the DIY) and wire harness. everything you need for the mod - $280
PD150 intake with machined aluminum adapter to fit NA egr that i had made, will make it a perfect swap without any modification.- $280
OEM oil pan with new tube of oem sealant - $70
Autometer A-pillar double gauge pod - $20
Jetta vents with the wire harness to do splicing with so they can be disconnected (for the Golf drivers that want to switch) - $60
W8 Passat Dome light - sold
Here is the vortex link with pics
PM or email dennisyue75@gmail.com
