Is it possible for sure to place a TDI engine in a canadian eurovan which currently houses a 5 cylinder diesel and a manual 5 speed? Would appreciate a correct answer.
Only vast sums of money and time would make it possible. If you need more pep you might have better luck finding a turbo and manifold that will fit and looking to have the pump redone with an LDA. I sooo wish that there was an easy swap of TDI into Eurovan because I could use the extra buffer between me and the kids..earplugs for now.
There have been numerous conversations here regarding this. In Europe the T4s were offered with either 4 or 5 cylinder diesels. So it's plausible to place either engine in with factory mounts.
I have an 2.5L TDI engine and manual trans but as of yet I haven't found the proper donor T4. Ideally I'd love to purchase a LWB Eurovan to convert.
Look up Petr here under vw4motion. I know that he's able to get T4 tdi powerplants.
