SRHeer
I am trying to read 97 Passat's engine fault codes. My Bentley Manual talks about using a VAG 1551 or VAG 1552 SCAN TOOL. But what I wanted to ask is can I purchase an adequate substitute and from where to check my ECM codes. The reason I want to check my fault codes is that my 97 Passat surges on start up and then after bit check eng light comes on.
Also is there a program and adaptors that one can hook up to their lap top or computer to do the same job?
Thanks for your help!
Stephen
Houston TX
281-464-8198
Stephen
Houston TX
281-464-8198
