Dead Larry
Hi All, So after finding my timing belt had a little slop, I changed it and the water pump. Borrowed the right tools to lock the crank and the cam.
Rolled it over and checked it. 5 times just to be sure. Fired it up and it ran great. Shut it off to reassemble the front end. Went to start it the next morning and it cranked but just will not start. tryed vagcom to check for codes and at first it said there were 2 codes but would not identify them.
Went back and checked codes again and it said no response from controller
or not communicating or not supported. Called Rosstech and the told me to charge the battery and unplug controlllors and reconnect them. Been there done that. Engine no start. Checked tank pump. Pumps lots of fuel. I am not getting fuel into the engine.
Just to make sure I didn't screw up I had the compression checked.
575 even across the board. The place where I had the compression checked had a Golf BEW and we hooked up the lap top to it and got the same response. We also hooked it up to a 2.0 liter gasser and found identified codes.
So, anyone know how to get the codes out of a PD?
And.......Why won't my engine start?
