ANyone ever do Vag-com logging at cruising speed, WOT, idle, etc. comparing the actual/requested IQ at different operating states? I have. WOT IQ doesnt change. Steady state cruising IQ doesn't change. Still the same requested and actual IQ except at idle, or just off idle.
Flame shield- ENGAGE!
Charlie, I have done plenty of VAG-COM logging of the various IQs blocks/fields over the operating regime, and I share your observation.
As a matter of fact, this was going to be my next TDI 101 mythology lesson!!!
The adapt IQ (AIQ) is only in play at and just off idle, that's it. It is the
indicated fueling value used by the ECU as the actual fueling value when the driver requested fueling value is below the AIQ value.
For example, AIQ set @ 5, at idle, foot off pedal, Actual IQ (ActIQ) reads 5, driver requested IQ (DRIQ) is zero. Step on the pedal a bit, ActIQ reads 5, DRIQ reads 1. Step on the pedal a little more, ActIQ reads 5, DRIQ reads 3, step on the pedal a little more, ActIQ reads 5, DRIQ reads 5, step a little more, DRIQ reads 7, ActIQ reads 7.
If the AIQ is 5, the indicated ActIQ will be 5 for DRIQ values <5. Once the DRIQ exceeds the AIQ, the ActIQ will then track the DRIQ.
That's all the Adaptation IQ value does.
Therefore, how folks report changes in power & smoke is interesting, since actual fueling is unchanged by the IQ adjustment.
