Old November 10th, 2019, 14:54   #1
summerboy1958
TDI(s): None yet
Default Mk7 Issues
Folks,
I have been looking for a replacement for the 07 Honda Fit that I stupidly wrecked. I have a 54 mile round trip every day (90% I-95) so have been looking at Prii, Honda Fit's and newer Corollas. I have mostly been focused on Hondas and Toyotas, as that is what we usually buy (for their vaunted reliability. We have had good luck with them). I came across a video of the '15 Golf Sportwagen TDI and was surprised to see them offered for sale. I really haven't paid much attention to VW's after the "DG" episode. However, I saw that they were offering an outstanding drive train warranty on the refurbished TDI's. My family has owned VW's in the past. My 1st car was a 1977 Champagne Edition Rabbit 2D with a 4MT purchased new. My sister had an old K Ghia (2 speed semi automatic), my brother a '73 Bus. My dad got us started with a '63 Beetle he brought over from Spain when he was in the Navy.
Anyway, I drove an 2015 GSW SEL with DCT and, despite the "automatic", I really like it. Far better than the Prius V I test drove. To be fair, the ride of the Prius V was smoother (smaller wheel, bigger tires) and the tech was better, but everything else wasn't. I am thinking about an SE or SEL 6MT (as i really don't understand the DCT and it looks overly complicated. I usually equate that to opportunity for failures).
I have been trying to understand why VW's have such a negative press on reliability. After a lot of poorly worded searches, it seems that there are a couple of bigger issues, namely the exhaust fluid doing injector, the HPFP and the DPF. These, however are covered under the revised warranty. So I am trying to understand what other "typical" issues there are. For example, my old Subaru's used to eat up brakes and CV joints (every 20k miles).
I did find a thread in here and besides a few pages lost to a rant, it discussed the dribbling rear washer, the CEL coming on intermittently, the door that leaked underneath, AC compressors failing, something about the steering hesitation or sticking, a heater core, glow plug failures, brake chatter backing up, etc.
I would really like to know if these are all just one offs or if there are some know, repeating issues (know to the TDI owners, anyway). The reason I ask, I am trying to decide between spending extra to buy a VW CPO to get the 2 yr B2B warranty or go for a refurb'd model with a good carfax (and a VW dealer inspection).
The refurb'd GSW are rare around me, rarer yet with the MT. I have to go an hour or more just to test drive one.
Any help would be appreciated.
Thanks!!
summerboy1958 is offline   Reply With Quote
Old November 10th, 2019, 15:33   #2
soot1
Today's VWs no longer are what they were 20, 30 or 40 years ago. Since you are familiar with the DG affair, you will know that any 2009-2016 2-liter diesel was covered by the settlement, which required VW to either buy the car back or fix it with a financial incentive to the owner. From the get-go, it was clear that vehicles that will be fixed will not perform quite as well as before the fix, hence the incentive. VW is now free to resell those vehicles they bought back, but only after performing the fix. It seems that quite a few owners of the fixed vehicles are experiencing issues with the emissions system (EGR and DPF, for the most part) that were present to some extent before the fix, but are now exacerbated. If reliability is on top of your list of priorities, you may be better off with either Honda or Toyota.
soot1 is offline   Reply With Quote
Old November 11th, 2019, 19:55   #3
summerboy1958
TDI(s): None yet
Anyone else?
Old November 11th, 2019, 20:39   #4
shortydog
In March I bought a 15 Golf SEL with 35k CPO car. I have a 120 mile daily round trip comute from home to work. 90% is highway driving. I'm now at 60k and had the water pump replaced under warranty. Other than the water pump being replaced around 50k miles, I haven't had any issues with the car. Only time will tell about the reliability.
shortydog is offline   Reply With Quote
Old November 12th, 2019, 16:57   #5
adjat84th
adjat84th's Avatar
Fuel Economy: ~50 in mixed driving
I think you mean DSG rather than DCT. It's not overly complicated, it's literally a manual gearbox with a mechanical unit that automatically does the shifting. They've been rather reliable for an auto box. Fuel economy ratings don't typically relate to real world when comparing to the 6MT, and most report better with the 6MT.
If you have normal traffic in your commute, I'd not hesitate to get the DSG for that bit of comfort in traffic.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
adjat84th is offline   Reply With Quote
Old November 12th, 2019, 17:18   #6
summerboy1958
TDI(s): None yet
Yep, I meant DSG.
Old November 12th, 2019, 17:28   #7
turbobrick240
turbobrick240's Avatar
VWAG makes some of the better dual clutch gearboxes. They are actually more robust in many ways than the 6mt. I can't argue with anyone who prefers to row their own, though.
Old November 14th, 2019, 09:29   #8
740GLE
Every car has issues, some people think one brands major issues is common place on another brand.
VW is by no means perfect and if you hold the car to standards above a "compact economy car," you'll be let down.
one of the things that I enjoy is the fact that if you have an issue with your car, another VW owner has probably had that same issue and can guide you through a fix.
Old November 14th, 2019, 09:38   #9
Even with the fix and the great warranty VW is offering (not that they had a choice), I'd be hard pressed to tell you that a GSW is going to have the reliability of a Toyota or Honda. It just isn't. Even if repairs are covered, odds are you'll have more of them than you would with one of the Japanese brands. As long as you're OK with this, then the VWs are a much, much better drive than the other cars you're considering. Don't be put off by the DSG: It's been very reliable.
If you have the inclination and skills to do some routine maintenance yourself (filters and fluids, tire rotations, etc.), then VWs are pretty economical to own. I've had great luck with mine, but since I talk to owners all day (at IDParts), I know that others have different experiences.
Still, VWs are addictive.
2002 Jetta wagon, 400K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old November 14th, 2019, 12:04   #10
MattRabbit
I've had 3 Golfs plus my wife's 2014 Beetle, all diesels - a 1981 Mk1 Rabbit, a 2001 mk4 Golf (ALH), and my new 2015 mk7 Golf TDI. The Rabbit has 320K miles on it, the mk4 Golf had 393K on it when I sold it, and the mk7 is up to 60K miles.
The mk4 was the most reliable car I've ever owned. I started calling it 'Chuck Norris' because it wouldn't die. It was starting to have things go wrong that go wrong at high mileage (alternator, AC Compressor, etc), but for the most part that thing was bulletproof.
The mk7 has been flawless over the 11 months that I've owned it. I've put 17K miles on it without any problems whatsoever. It gets about 40mpg with 60/40 highway/city driving.
We've had the Beetle TDI for a year and a month. It has also been flawless, though it only had 20K miles on it when we bought it. My wife loves it. It gets about 31mpg city and 40 highway.
All of our VWs are manuals. I've never owned an automatic. The manuals last forever if properly cared for. They are very durable.
My parents own a 2016 Prius C. It gets better mileage than my Golf in the city, but can't match it on the highway. It's been fairly reliable, but it's starting to have issues with the paint - like, it started peeling. Toyota doesn't want to cover it, either. YMMV, of course.
I tend to stick with VW as they're economical and fun to drive. I like the diesels - it's true what they say, they get into your blood. This mk7 is probably the last one I'll own though, as there won't be any more to buy after this. That's ok, though... I'll go electric!
Good luck with your purchase decision.
2015 Golf SE TDI (Mine!)
2014 Beetle TDI (Wife's car!)
1981 Rabbit Diesel (Purchased new by my parents when I was 7. I still own it)
http://matt_lisa.home.sprynet.com/
MattRabbit is offline   Reply With Quote
Old November 14th, 2019, 17:47   #11
bigb
Just about a year and 9K put on my 2015 GSW that I bought with 26K on it, no complaints, I absolutely love the car and not any issues except cruise control dropping out two times.
Brian...
bigb is online now   Reply With Quote
Old November 15th, 2019, 17:46   #12
15TDICommuter
TDI(s): 2015 GSW
2015 TDI DSG GSW owner here. Bought the car with about 32k miles in January of the 2019. Currently sitting at 65k. No complaints or issues. Did the 40k service on my own and just the normal stuff (oil, tires and washing).
Love it. I like the DSG since its my daily. I get the fun in 'rowing gears' but for a car that gets me to and from work, I just wanna go. The Z06 handles the desire to row.
15TDICommuter is online now   Reply With Quote
Mk7 Golf R springs on a Mk7 GSW TDI? nathanso VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 7 September 30th, 2019 07:45
Mk7 Common issues and resolutions JASONP VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 517 September 24th, 2019 13:39
Page generated in 0.15042 seconds with 12 queries
[Output: 108.19 Kb. compressed to 91.50 Kb. by saving 16.68 Kb. (15.42%)]
