Bigleondriver
I have a 110 non pd 05 mk1 leon.
the car has the following done to it.: straight pipe exhaust, pancake pipe, .216 injector nozzles.
I was also told by the previous owner that the car had been remapped prior to any of the mods which I have since preformed.
The car was fine until I installed the .216 injector nozzles, since these where put into the car I have been getting an engine light, when I checked what it was on OBD scanner it shows p0324 (turbo over boost). This will only come on in 5th when I go over 100 mph. I have tried unplugging the air flow sensor, which had been advised on another thread, this had little to no effect on the way the car run, and still threw the engine code. Another issue which I believe may be linked to this came about, I started my car and went to drive off, I got about 10 metres, and the car cut out, when I tried to start the car, it struggled to start, and there was a whirring sound, like a motor, but the engine didn't turn over, I left it for about 2 mins, and tried to start it up again, after a while the car started up, and there was a lot of white smoke and a rough idle, I left the car running for a while and this seemed to clear up, there was still a bit of white smoke, but hard to till with all the black smoke, I drove the car home and noticed no difference in power, it has been two days since this happened, and the car seems to start and drive fine, although I haven't tried going passed 100mph. I was wandering could anyone tell me what was wrong with my car, and would another remap solve, or help this.
