themotherlandcar
Hey all,
So just bought an 05 passat wagen TDI with 68K mi. After bringing it home I noticed that the door lock switch works intermittently. When using the key fob, only the pass side front door locks.
When I hit the unlock button, the doors sound like they are unlocking with the exception of the pass front door. It does not unlock no matter if I use the key fob or the button on the door. It only unlocks by manual opening the handle.
The other weird thing is that the driver's door lock will not go down if I manually push on it to lock.
Any thoughts? a safety sensor? bad door lock switch?
