Windows - sunroof opening on their own
Mark_J
Deer Park, Washington
2015 TDI Passat SEL Premium, 2017 Fiat Spider, 2017 Ford F350 6.7 Diesel crew cab PU, 2016 Harley Trike, 2016 Tesla Model X P90D (I know went to the dark side)
I have seen other posts regarding this issue and researched this, but I was hoping someone might be able to point me in the right direction regarding a couple of faults I have from my scan. Not really too worried about #37 & 75 unless these are pointing to something more serious. The vehicle is a 2015 Passat SEL Premium TDI and of course it is just past warranty. Thank you in advance.
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: 1VWCV7A34FC047441 License Plate:
Mileage: 58620km-36424mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 75 77
VIN: 1VWCV7A34FC047441 Mileage: 58620km-36424miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
75-Telematics -- Status: Malfunction 0010
Address 01: Engine (J623-CVCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 997 016 D HW: 04L 907 309 K
Component: R4 2.0l TDI H20 9466
Revision: 8AH20---
Coding: 011D0012032410089000
Shop #: WSC 19115 444 00000
ASAM Dataset: EV_ECM20TDI01104L997016D 004002
ROD: EV_ECM20TDI01104L997016D.rod
VCID: 346D70F29F2D2AEA09-8060
2 Faults Found:
19225 - Boost Pressure Regulation
P0299 00 [032] - Control Range Not Reached
Intermittent - Not Confirmed - Tested Since Memory Clear
22566 - Reductant Injection System
P249C 00 [096] - Excessive Time to Enter Closed Loop
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 061 T HW: 02E 927 770 AL
Component: GSG DSG AG6 531 4518
Revision: 05653104 Serial number: 00001409020096
Coding: 0000020
Shop #: WSC 09003 957 00200
VCID: 254B9DB6ECF743628E-8070
1 Fault Found:
28907 - No Communications with Cruise Control (Front) Distance Sensor
U0235 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 65
Reset counter: 28
Mileage: 30741 km
Time Indication: 0
Date: 2018.06.19
Time: 00:02:03
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3C0 035 684 Q HW: 3C0 035 684 N
Component: RNS-MID H26 5382
Revision: AB001001 Serial number: VWZ6Z7P9265165
Coding: 04090042010000A6000B
VCID: 316379E6683F1FC262-8064
Subsystem 1 - Part No: 7L6 919 859
Component: NAR V8 8112
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 5
Fault Frequency: 4
Reset counter: 175
Mileage: 40933 km
Time Indication: 0
Date: 2018.09.19
Time: 10:05:25
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 175
Mileage: 40933 km
Time Indication: 0
Date: 2018.09.19
Time: 10:05:25
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0102
Serial number: 000003554140528
Coding: 02140102C2423A007F1606000000
ASAM Dataset: EV_OCULow 001010
ROD: EV_OCULow_001.rod
VCID: 53AF136E3AE30DD230-8006
1 Fault Found:
2103041 - Control Module
B1788 F0 [009] - Start Prohibition Deactivated
Freeze Frame:
Fault Status: 00000001
Fault Priority: 8
Fault Frequency: 1
Reset counter: 135
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
jrm
Oregon
2013 Passat SE with nav (totaled)
Passenger side view mirror on my 2015 moves around on its own as well, super annoying- im about ready to pull the door panel and remove the wiring to the thing!
