UncleK
I am looking for someone who is familiar with the 2013 2.0 TDI engine (CKR).
On a previous post I was trying to diagnose a crank, no start condition and found lots of information on older style engines which led me down a rabbit hole (but I did learn a lot about these earlier TDI motors).
I am now far enough along that I suspect a cam sensor issue.
Since we are this far along on tearing down this motor (140K) we are wanting to change the timing belt and have found the front main seal leaking and needing to pull off the pulley for the belt. On other TDI motors it showed a place to put a special tool to lock the crank into place while taking the bolt out (180 ft lb) but have not had any luck finding something like that on this motor.
So any help with getting this bolt out without tearing something else up will be greatly appreciated.
