Przemix
Hey Guys anyone knows which IN TAnk Fuel Pump is best to get?
I have 2006 VW Golf TDI BEW 1.9
I have 160 K on the engine and never replaced the pump and recently started having problem when temperature dropped to 25F , I never had that problem before , also when I finally started the engine after many times cranking it I let it warm and i gave it a lot of rpms and let go the gas pedal and it shut down again like there was no fuel, even when it warmed up it didnt want to start, I checked the fuel filter and it was ok, so the only way I could start it was with Engine starter spray :/ and I gave i think a litlle too much because it went on high rpms and sudenly everything started to work properly.
Was the pump clogged and under engine starter spray it created big suction and maybe unplugged it?
I put 911 and other injector and pump cleaners addetives to the fuel when it didnt want to start.
I changed my temp sensor and Brand new NGK glow plugs and new wires too
Car starts now immediately even in cold temperatures but im afraid it might happen again because of old clogged in tank pump, how often should we put diesel additives there ? every time we fuel to keep pump alive and clean of dirt?
anyway...
I need to get a new in tank pump and keep it in my car if that happens again.
now... I have no idea about the pumps at all. I see on ebay they have so many with different prices and Im confused which one to get : / please help
$68 Fuel Pump Module with Sending Unit for VW Jetta Beetle Golf L4 1.9 TDI Diesel
https://www.ebay.com/itm/Fuel-Pump-...e=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649
$209 OEM VW Diesel PD Fuel Tank Lift pump Mk4 Golf Jetta Beetle TDI Diesel VDO 1.9
whats PD?
https://www.ebay.com/itm/OEM-VW-Die...e=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649
or even for $285 Fuel pump !!!!!!!
$285 PD In-Tank Lift (Fuel) Pump MK4 BEW 1J0919050
https://www.ebay.com/itm/PD-In-Tank...e=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649
Its almost 2018 and they must have upgrade them or something right? I tried to read about those electronic lift pumps that gives 5-8 PSI pressure so the cheap ones dont have it ? or all of them have it and they are just trying to rip people off because of the brand?
Which one should I get ?
thanks for reading and sorry for mistakes, English is my second language.
thanks again.
anyway...
whats PD?
thanks again.
