tigers2007
1997 B4 Passat TDI sedan $1000!
1997 B4 Passat TDI sedan $1000 ( S O L D )
VIN: WVWGG83A1VB007483
**Comes with a set of Snow Tires**
Service History:
9/29/15 to 5/25/16 vehicle stored inside garage.
6/18/16 New battery. EverStart Maxx H6. 228,438
6/18/16 Replace N75 valve. Pierburg 028 906 283F from IDParts.com 228,438
9/19/16 Replace pigtail harness to injector pump due to broken wires.
I have owned this car for a few years now and it has been a fun ride. I replaced many parts and it drives like a new car (replacing the rubber bushings changed everything...). It has a block heater and comes with a set of snow tires on steel rims. It runs and drives excellent. All the lights work, the cruise control works fine, heat works and the A/C is ICE COLD. The air re-circulation function for the A/C even works. I have installed new leather shift and parking brake cables. The car is located in Northern Michigan at this time. The reason I am selling this car is that I have too many cars! Feel free to send me questions via PM.
Edit history: 9/22/2016 lower price
Edit history: 3/16/2017 lower price
Edit history: 6/9/2017 sold.
Service History:
Date Description Mileage
5/20/13 Oil Change 5W--‐40 Elf Synthetic and Bosch Filter
6/5/13 Replace Timing Belt, TB Tensioner, Cam seal, Idler, Serpentine and AC Belt
9/7/13 R&R rebuilt Alternator 214,626
9/11/13 Repair speedometer problem with sensor 214,626
9/11/13 Oil Change 5W--‐40 Rotella T6 Synthetic and Mann Filter 215,342
9/11/13 R&R A/C high pres refrigerant pipe, R&R receiver drier, recharge 1150g R--‐134a 215,342
9/25/13 Replace both front wheel bearings (FAG bearing kit) 215,645
9/25/13 Remove Left Outer CV joint, clean, regrease, new boot 215,645
9/25/13 New front brake pads 215,645
10/10/14 Replace turbo oil supply line. Add 4qts fresh Rotella T6 221,800
Winter 14/15 ***Out of service for winter maintenance *** 222,661
2/1/15 Replace rear: brake calipers, pads, rotors, hoses, copper lines. 222,661
2/1/15 Replace parking brake cables (both sides) & rear wheel bearings. 222,661
2/1/15 Replace all front and rear struts. 222,661
3/5/15 Replace passenger side rear engine mount. 222,661
3/16/15 Replace driver side tie rod end. 222,661
3/17/15 Replace cabin air filter. Bleed clutch system. 222,661
3/18/15 Professional Alignment
4/12/15 Replace steering rack & pinion. Flush power steering system.
4/12/15 Install power steering filter, replace outer tie rod ends.
4/12/15 Replace left control arm. Replace all control arm bushings.
5/8/15 Replace lower ball joints. Lube shifter & wiper mechanisms. Align again.
6/28/15 Oil Change 5W--‐40 Rotella T6 Synthetic and Mann Filter W940/25 225,2429/29/15 to 5/25/16 vehicle stored inside garage.
