VW DTC 16989 (P0605) - Internal Control Module Read-Only Memory (ROM) Test Error
n75 will trip a different code.
most of the threads about this code all point to the ECU having a issue with a Tune. well all the threads i could find on this. Nothing about a boost leak.
these would be the codes you would replace the boost lines with.
00575 - Intake Manifold Pressure
17-10 - Control Difference - Intermittent
http://wiki.ross-tech.com/wiki/index.php/00575
however:
according to rosstech
Fault Codes like this can usually not be repaired since they are stored after the Control Module did not pass it's internal Self Test. Even though the official Repair Manuals suggest replacing the Control Module in such a case, there may be specialized Companies repairing Modules like this.
http://wiki.ross-tech.com/wiki/index.php/16989/P0605/001541
Please provide me with the links to your DIY threads about replacing the boost lines for this code becuase i have not found any.
AGAIN, your fault codes cant be cleared, sorry if i didnt specify that in my last post but this and a few other faults CAN NOT be cleared, well easily any ways. Im asuming you are using a generic scanner or do you have a VAG-COM cable and VCDS? you WILL need this cable tool to do this job.
90% chance you need to replace the ECU or repair it some how. Has it ever been tuned?
