maloosheck said:
Full scan would help. Are you sure you have not messed the CCCM coding? SAFE is an Euro option and requires different door locks.
I am not sure if the CCCM coding has been altered. I really don't know how the handheld scanner the shop used worked or what it might have done. I'm not aware of doing anything to the CCCM myself but I'm not sure how I would do it and may have done something by mistake. Below is a scan taken tonight:
VCDS Version: Release 908.1
Data version: 20091018
Tuesday,26,January,2010,20:19:49:20631
Chassis Type: 1K0
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 47 52 56 62 72
7D
VIN: 3VWDT71K26M030315 Mileage: 108720km/67555miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: RC s01e EDC G000SG 7550
Revision: --H02--- Serial number: VWZ7Z0F4477415
Coding: 0050071
Shop #: WSC 00066 000 00000
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BJ HW: 1K0 907 044 BJ
Component: ClimatronicPQ35 090 0909
Revision: 00090016 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000000407868
Coding: 15018E1700041501070A00000500000000215D035C0000
Shop #: WSC 01404 444 53924
Part No: 1Q1 955 119 A
Component: Wischer 020208 022 0501
Coding: 00065493
Shop #: WSC 01404
2 Faults Found:
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 60
Reset counter: 107
Mileage: 108689 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.05 V
ON
ON
OFF
OFF
OFF
01334 - Door Control Module; Rear Right (J398)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 60
Reset counter: 107
Mileage: 108689 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.05 V
ON
ON
OFF
OFF
OFF
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7F2033447
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D05A79L
Coding: 0013889
Part No: 1K0 959 339 F
Component: BF-Gewichtsens. 007 0005
Address 16: Steering wheel Labels: None
Part No SW: 1K0 953 549 AS HW: 1K0 953 549 AS
Component: J0527 035 0070
Coding: 0002021
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 973 D HW: 1K0 920 973 D
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0F4477415
Coding: 0021207
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001066231520
Coding: 3D7F0B620F001002
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 108689 km
Time Indication: 0
Date: 2000.00.00
Time: 13:28:04
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 108689 km
Time Indication: 0
Date: 2000.00.00
Time: 13:28:04
01304 - Radio
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 146
Mileage: 108689 km
Time Indication: 0
Date: 2000.00.00
Time: 13:28:08
02649 - Digital Radio Tuner
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 146
Mileage: 108689 km
Time Indication: 0
Date: 2000.00.00
Time: 13:28:08
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0003
Revision: 00005000 Serial number: 1293324T20XE01
Coding: 0000003
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO 3HL 1610
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 C HW: 3C0 959 760 C
Component: Sitzverstellung 1001
Revision: 00004000 Serial number: 00000000000000
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1125
Revision: 11006001 Serial number: 00000578068721
Coding: 0001343
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CD HW: 1K0 959 433 CD
Component: KSG PQ35 RDK 051 0215
Revision: 00051000 Serial number: 00000000000000
Coding: 1A900C880186003F2401048CB08A8F00887E00
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No: 1K6 035 456 A
Component: 08K Audioverst. 0005
Revision: 00003000 Serial number: 00000000005618
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1125
Revision: 11006001 Serial number: 00000624268721
Coding: 0000063
1 Fault Found:
00097 - Front Passengers Central Locking (Safe) Motor (V162)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 147
Mileage: 0 km
Time Indication: 0
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 G HW: 1K0 035 180 G
Component: Radio DE2 014 0017
Revision: 00014000 Serial number: VWZ4Z7G2143164
Coding: 0010011
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
End ---------------------------------------------------------------------
The radio has been a problem for some time so I have disconnected it. That is why it throws a code. The locks have rear door/windows have always worked since I disconnected the radio so it's nothing new.
Although the door electric passenger shows an intermittent fault the window works and so does the door lock. I did a scan to find all the modules and have that if it would be of use.
Any ideas appreciated.
