Terminal release tools make wiring the tasks of wiring modifications or alterations feasible. However, in my research the commercially-available release tools are expensive and hard to find. I decided to make my own. I used the methods explained (By Wingnut: http://forums.tdiclub.com/showthread.php?p=672727) in the paperclip release tool method, but in my experience the paperclip didn’t offer enough structural rigidity to free stuck terminals. I went in search of an alternative almost as plentiful as the paperclip.
Materials needed:
1- Binder clip, small size
Tools Needed:
1- Pair of needle-nose pliers
1- Bench grinder, or alternatively, a file
1- Hammer
A piece of wiring containing the terminals inserted into a wiring connector helps during the fine-tuning process, to know when your terminal release tool is working (see below).
http://pics.tdiclub.com/showphoto.php?photo=89693&title=dscf16751&cat=500
Finally, I settled on the binder clip as having the necessary strength of steel to handle the task. I went ahead and removed the tabs from the clip by compressing the spring force holding them into the clip.
http://pics.tdiclub.com/showphoto.php?photo=89694&title=dscf1676&cat=500
Once I had the tabs free from the clip, I began to form them into the shapes necessary to remove both the “micro” (found in CD changer connections) and the “junior” (found in headlight switch connections) sized terminals present in my Mark IV. Two binder-clip tabs = two sizes of terminal release tool.
http://pics.tdiclub.com/showphoto.php?photo=89695&title=dscf1677&cat=500
http://pics.tdiclub.com/showphoto.php?photo=89696&title=dscf1678&cat=500
Here, I have taken a pair of needle-nose pliers and bent the end of the metal tab straight, then to a slight angle to the inside, so that the ends of the clip point towards each other slightly. From here, it is a good idea to bend the clip apart in order to be ground on the bench grinder. This may not be necessary with the file method.
http://pics.tdiclub.com/showphoto.php?photo=89697&title=dscf16801&cat=500
Begin grinding or filing on the first clip until it gains the shape of the “junior” size release tool, which is the larger of the two shown. Here is a photo of the tools I have made in the past. I took most of the material off of the inside of the clip, then proceeded to taper the sides and outside, if necessary. A hammer can come in handy to flatten the end of the clip to obtain the desired shape. Try not to decrease the total length of the clip in this process, a longer tool helps when reaching deep terminals. See photos of completed tools below.
Once a suitable tool has been created, use a wiring connector to test the shape of the prongs. Remove the purple or black locking tab from the connector, and insert the tool with the prongs surrounding the terminal’s top and bottom. It helps to know the shape of a removed connector when first attempting this, but it is not necessary. If the tool doesn’t work, try to alter the shape slightly until the perfect shape is achieved and the tool works to remove the “junior” size terminals. Another trick is to angle the ends of the prongs inward slightly to better depress the terminal locking tabs.
You now have a tool that will release the larger of the terminals; the “micro” tool is next. This one is smaller and a bit more tedious to get right. With the success of your “junior” tool, this shouldn’t be difficult. The prongs have to be tapered from the sides to a greater degree to fit the smaller connectors used to hold the micro terminals, otherwise it is the same process as was just completed. Be careful not to decrease the length, and use a spare wiring connector to test the tool. Eventually it will work, this is the shape I achieved with my “micro” and “junior” tools.
http://pics.tdiclub.com/showphoto.php?photo=89707&title=dscf1690&cat=500
Congratulations, you now have a set of terminal release tools for about $0.10, a far-cry from the $50+ prices charged for the commercially-available tool. Not to say they aren’t worth the price. Doubtless those are more comfortable and will last longer, but for the home mechanic you can’t beat the price of a home-built solution.
http://pics.tdiclub.com/showphoto.php?photo=89702&title=dscf1685&cat=500
http://pics.tdiclub.com/showphoto.php?photo=89703&title=dscf1686&cat=500
http://pics.tdiclub.com/showphoto.php?photo=89709&title=dscf1692&cat=500
There are websites that detail the use of the tools, just search “terminal release tool”.
Please let me know if there are any questions. Thanks for reading!
Materials needed:
Tools Needed:
1- Hammer
