maloosheck
I am interested in replacing my BRM for CBEA (once they hit junk yards) and upgrade it to the oem 170HP (before further modifications, of course).
I did some part no. research and it seems the task is doable and does not require exchanging the whole engine.
I compared the parts of several TDI CR engines:
1. EU-spec Tiguan/Passat: CBAA/CBAB (140HP), CBBA/CBBB (170HP)
2. EU-spec Jetta: CBDA/CBDB (140HP), CEGA (170HP)
3. US-spec Jetta: CBEA (140HP)
The following parts need to be replaced for sure:
1. exhaust manifold and turbine
2. exhaust, DPF, and the rest of the exhaust (it is wider: 60mm vs. 55mm)
3. water pump
4. ECU
5. flywheel/clutch
The following parts need to be most likely replaced:
1. injectors - they are different for US, but I am not sure what the differences are.
2. intercooler - again, different for US
The parts that are different, but the replacement would be optional:
1. oil pan - no oil sensor for US
Everything else is the same (block, head, shafts, bearings, rods, valves, pumps, rails) among these engines.
Is there anything in particular that I should take into account or look for? I mean a particular part?
3. water pump
4. ECU
5. flywheel/clutch
