mcquinn
I replaced the cylinder head on my 2002 automatic and now have such a LOUD clatter that I can not drive the car in public. The far left lifter on my old head had worn through and I decided to replace the head rather than take a chance on having bad valve guides on the 179K engine. The pistons showed no signs of wear or damage when I removed the old head. Within the the last 6 months I have replaced the fuel filter, installed swap injectors from DBW, and completed the timing belt change. The timing is set between the top 2 lines on VCDS. My questions ... can the oil pump fail? What are the symptoms? If not an oil pressure issue, what could be causing the clatter? Thank you in advance for any suggestions.
