gribur
starting a fresh post, Any questions here will be ones that have me stuck and have brought me to a grinding halt or at least slowed me down. I am swapping an AAZ from a donor mk3 golf into a gasser mk3 golf.
right now i am stuck with a couple things.
A) The gasser has no engine or tranny in it but a few items were left when i bought it. It has shifter and cables from what used to be a hydraulic clutch. mine that i will be swapping over is the old school shifter. I need to know if I need to swap the entire pedal assembly from the donor golf into the gasser shell? From what i can see, the gas pedal and the clutch pedal look different between the two golfs.
B) Do I need to swap the brake booster and master cylinder from the aaz golf over to the gasser shell? They look the same except that the gasser resevoir has a hose from it that I am assuming was for the clutch.
Thanks guys, I am hoping that someone will know the answers to my questions so I can keep a good pace going on this swap. I will be posting more I am sure, and yes, I am searching for the answers, so anything I post is something I cannot find a specific answer to.
