ken.fresno-tdi
- Joined
- Jan 3, 2006
- Location
- Fresno, CA
- TDI
- 95 Eurovan EVC camper with 98 AHU engine (VeganVan02); 01 Jetta ALH engine and parts - waiting for transplant into 97 Eurovan (VeganVan03);05 BEW Beetle
Hi all,
I recently bought a 2005 TDI BEW Beetle with 175,000 miles from a friend. Planned to replace the timing belt as soon as I got home but on the way home the timing belt broke :< . (what are the odds!). Fortunately she paid me for a replacement head as the belt replacement was 15,000 miles overdue. Put on the head and successfully started the engine after about 2 minutes of intermittent cranking, which I assume was because fuel lines needed clearing of air. It ran at idle for about 30 seconds and then it just stopped; I can't get it started again. I've changed many timing belts on ALH's but this is the first head/timing belt on a BEW. I have the proper timing belt tools and triple checked cam and crank TDC positions and torqued everything to spec before initially starting it.
I have VCDS - no codes.
I used a mity-vac to pull the fuel through the fuel system. It took about 15 seconds to get any fuel and after that fuel with quite a few bubbles - is that normal? (In ALH it is not so I am assuming it is not o.k. with BEW as well). To pull fuel through I disconnected the return fuel line just before the fuel filter and also plugged the filter return fitting.
I then cycled the fuel pump about 6 times using VCDS basic settings block 35 - but no luck starting it.
Charged the battery overnight and made sure cranking was good.
Since no codes I assume the cam and crank sensors are o.k. I did not replace them when I had the head off.
What else to check? I suppose it could have jumped a tooth on the timing belt but seems unlikely - is there a way to check crank TDC without taking the pulley and lower timing belt cover off? What else to check?
Thanks for any help!
Ken
Ken
