poormanq45
2006 Jetta TDI
186000 miles
DSG
This issue started intermittent a few weeks ago. Driver's door opening/closing state while it was in the closed position. This resulted in a few dead battery occurrences until I added a maintainer.
I have VCDS, so if there are any logs or outputs that you all would like let me know. Contact Switch(F2) on the driver's door is showing open at all times. When going through the output tests on the door, everything functions, including the unlock test.
We replaced the driver's door harness about 30k miles ago, currently at 186k. The 80mm longer one was used for replacement. I think that was ~2-3 years ago.
Thinking that the harness is fine due to the previous replacement, I chose to order the door switch. I just installed it today, same exact condition occurring. Contact Switch(F2) - Open.
I am at a lose on this one. Is it possible that two switches are independently bad in the same exact way, not even intermittent functionality? Maybe another harness failure? What else could it be?
Any help is greatly appreciated.
186000 miles
DSG
