Yea, it's too bad manufacturers don't point out these things in the owners manual. The debris will eventually eat the end of the rocker panel, hard to repair, then there's the fender.In the process of installing new OEM front splash guards, I decided to look behind the wheel well liners. Woah! I was expecting a bird to fly out of the leaves and dirt collected behind the liners. Washed all the dirt out from behind the wheel well liners and let it dry out. Fortunately no rust.
Top Tip (I never knew this til recently) is to leave out the bottom fastener, making it easy to clean. When you install the new ones, leave the screw in for maybe 6 months, then remove it.
Ouch. Sorry to see that man.More like a “what did they do to your MKIV today?”
Hopefully, they didn’t take my VAGCOM cable in the glove box. They broke the handle and I can’t open it. Ugh
You can probably reach in where the handle was, there is two fingers that need to be pressed downwards.
I now have a double-DIN Monsoon radio that I'm no longer using. I upgraded -- but I suppose that's what you'll do now too.More like a “what did they do to your MKIV today?”
Woah, so what failed? And is your block done for?
If the handle is still there, push it back in like it used to be and actuate it and it'll open. Or push in and unlock the lock, then open.More like a “what did they do to your MKIV today?” post:
See if this helps, especially the last post.I installed the E-code headlights, European switch and ECS fog light wiring harness following their instructions exactly. I’m plugged into pin 8 on the Euro switch and plug 2 at the lights. First test, the headlights work, turn signals work but for some reason I can’t get the fog lights nor city lights to work. I’m stumped.
replaced installed vent fender liner, more air flow through the intercooler..
Does that fender liner fit the 2004 Jetta Wagon? If so, what is the part number?
Direct replacement, from ID PARTS 58 shipped was it stalled in this..
I modified the tweezers of a Leatherman Micra tool, to work as a wire-pin connector removal tool, and swapped wire locations on the Euro Switch, to resolve my fog light issue. Unsuccessfully, swapping pins didn’t fix the problem. About to give up, I decided to just check the bulbs... turns out the lights had all bulbs included and installed EXCEPT for the fog light bulbs. Quick run to the autozone for some H3 bulbs... we have fog lights! Pin 8 works for first pull on the Euro switch.
Next piece of the puzzle: How do I get the city lights to illuminate? Run power from the side marker lights?
