Glow plug and CE lights
Hasenwerk
Vendor , w/Business number
Quesnel, BC
1982 Cabriolet (BEW|VNT17|Stage4), 1989 VW TriStar Syncro soon-to-be CR TDI (CBEA), 2001 Ford Ranger Edge 4x4 (ALH|VNT17|R520|Stage4)
i have to disagree about using incandescents... been running stock toyota cluster incans for almost six years no issues ... perhaps these circuits are meant to run inandescent bulbs for applications other than automotive...remember they are not part of the mkiv stock warning lamp system but seem to be vestiges or intended for use in other applications ... the ecm's even have a tach output that's not utilized in the 121 pin cars ... i am using a pnp transistor circuit correct my CEL operation so that isolates the bulb "current" but i don't feel it's necessary to protect the ecm
Um you're just riding semantics with your disagreement . . .
You can't say, with a blanket, that you can run incandescent bulbs direct from an ECU. How many watts are we talking? Most cars, have tiny bulbs for the lights, however, there may be a combo out there that is too much current for the ECU and maybe not today or tomorrow, but one of these days you'll burn out the circuit in the ECU due to too much current. Hence, the smart idea to use an external circuit to handle the load and just let the ECU do the switching. If you don't think it's necessary to protect the ECU (even though you are protecting it with the transistor), that fine, however I will and will recommend that others do for the long term happiness of the ECU. The MOSFETs that I use can easily handle a 55W halogen if I wanted to - there no way the ECU was ever designed for that!
jimbote
Certified Volkswagen Nut
Tacoma 4x4 converted to TDI
i can say "with a blanket" ;) i've run MY glow circuit, UNPROTECTED, with an incandescent for over 100k miles, six years and thousands of cycles without frying the ecm... do your own research, it's a stock 1996 tacoma incandescent, and if someone reading this thread cannot infer that maybe running an H1 or even a tail lamp bulb might be a stupid move then they can certainly visit
https://www.fastforward.ca and purchase your moffsets... and you cannot say "with a blanket" that i'll burn out my ecm using incans any more than i can say you'll go blind reading this thread
fjdiesel
MN
76 fj40 w/05 LIberty CRD 2.8L diesel
Where are the wiring diagrams of jimbotes that are referenced for wiring in the MIL and Glowplug light?
