matiii1 said:
Anyone installed these on their TDI and what torque values did you use,the ones that came in the box or the torque specs from the repair manual.Only reason I ask is these things where made for the Ford Cosworth engine ,not a VW.Thanks.
I've installed over 4 sets of ARP headstuds the A4 TDIs.
Before this mod I was getting about 44MPG freeway on my 2002 Jetta TDI (Upsolute StageII/Upsolute FMIC/Sprint 520).
On my car with 85K miles, driving an indicated 75MPH on a non-altitude changing, relatively straight freeway I get 53.3MPG after doing this modification. I get 43MPG in the city.
Steps for proper ARP installation on the A4 TDI:
1. Unpack and clean with alcohol all the parts (gets the sticky packing grease off of them)
2. Prepare all of the bolts before starting by covering them all with the included ARP installation grease that is included. Basically, get it in all of the threads and cover all the washers, and bolts so that they look "grease grey" all over. On the nuts use a q-tip to make the threads on the inside grey with the ARP grease.
3. Remove your plastic engine cover, and crank case cover.
4. You'll need a from [FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1]
Part MN0812 - 12 Point Driver Set [/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT]from metalnerd.com or a similar [FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1]12 mm,12 point driver to remove the factory headstuds.
(NOTE: If you are going to use the metalnerd tool, it is long and will require you remove your EGR to get the one of the headstuds out. If you're removing the EGR, then this is a great time to cleaning out your intake and install an elephant hose, or CCV catch can and an Epsilonian device.)
5. Remove the 1st headstud. You will need a breaker bar, and it comes off with a scary "snap" sound.
6. Put your the first prepared ARP headstud in (allen wrench side up) and use an allen wrench to tighten it all the way down. Don't over tighten, just a little past snug.
7. Put the prepared washer and nut on the headstud and tighten it down Using a torque wrench and bring it to 65lbs. (ARP instructions on their website say to tighten, to something less than final torque, 5 times before final toque to seat the fastener correctly. Continue following these instructions to see how this is done)
8. Loosen it completely using a normal socket wrench (NEVER USE YOUR TORQUE WRENCH TO LOOSEN ANYTHING YOU'LL DESTROY IT!)
9. Use the torque wrench to tighten to 70lbs.
10. [/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1]Loosen it completely using a normal socket wrench.
11. [/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1]Use the torque wrench to tighten to 70lbs.
12. [/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1]10. [/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1]Loosen it completely using a normal socket wrench.
13. [/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1]Use the torque wrench to tighten to 70lbs.
[/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1]14. [/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1]Loosen it completely using a normal socket wrench.
15. [/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1]Use the torque wrench to tighten to 70lbs.
[/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1]16. [/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1]Loosen it completely using a normal socket wrench.
[/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT]17. [FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1][FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1]Use the torque wrench to tighten to the final 80lbs.
18. Hooray! You've installed your first headstud, now just repeat steps #5-17 over and over again until you're done.
