Old August 17th, 2017, 19:03   #511
DSIre
Default A3 Parts
Originally Posted by BleachedBora View Post
Hot off the press!
Parts list for Gen 1:
Kits:
1K0-298-101-A (I believe this is the 2010+ kit)
Includes the Following:
Part Number Description
1K0-253-120-B Pipe for exhaust Circulation
1K0-253-725-F Clamp
1K0-253-115-AG Gasket
03G-131-547-H Gasket
2x N -106-421-03 Bolt - M8x25
3x 1K0-253-115-AE - Gasket
1K0-253-725 Clamp
1K0-253-691-J Exhaust Flap
2x 1K0-253-725-B Clamp
03L-906-262-N Oxygen Sensor
3x 1K0-825-951 Bolt - M6x20
3x WHT-000-729-A Bolt - M8x20
1K0-971-461-D Heat reflective mat
1K0-971-461-E Heat reflective mat
1K0-971-461-F Heat reflective mat
1K0-298-101-X
I believe this is for 2009 models
03G-131-525 connecting hose
03L-906-088-EG emissions temperature sensor
03L-906-088-J emissions temperature sensor
03L-906-088-T emissions temperature sensor
03L-906-262-B oxygen sensor before catalyst
04L-253-115-A gasket
076-906-051-A differential pressure sensor
1K0-131-552-A control line
1K0-131-552-B Control line with differential pressure sensor
1K0-131-649 bracket for exhaust pipe
1K0-253-144-BC bracket
1K0-253-463-AF bracket for exhaust system
1K0-253-725 clamp
1K0-254-708-GX exhaust pipe with particulate. filter.
1K0-971-461-C Heat reflective mat
3x 3C0-131-483-A spring clip
4B0-422-379 spring clip
5N0-131-783 shield for catalyst
5N0-971-461 heat deflector hose
N -010-335-13 screw, hex. hd.
2x N -015-081-6 shouldered hex. nut
4x N -015-083-15 shouldered hex. nut
4x N -023-002-15 hex. nut, self-locking
2x N -102-400-03 bolt, hex. hd. with shoulder
N -104-562-01 bolt, with polygon socket hd.
N -106-531-02 screw, hex. hd.
N -907-371-05 Oval hexagon socket head bolt
2x N -907-865-02 bolt, hex. hd. (combi.)
6x N -909-910-02 bolt, with polygon socket hd.
6x N -909-911-02 bolt, with polygon socket hd.
4x N -910-398-02 bolt, hex. hd. with shoulder
N -910-661-01 bolt, hex. hd. (combi.)
N -911-671-01 bolt,hex.hd.with shoul.(combi)
2x WHT-000-431-A bolt, hex. hd. (combi.)
BB,
Would you have a list for the 2011 Audi A3?
The mailer said that it includes just the NOX catalyst and software.
Engine is a CBEA. But apparently Audi uses newer style parts than VW.
I did look from underneath and my "gen 1 CBEA" does indeed have a two part exhaust, so the NOX cat change should be a 5 minute job. Maybe 10 because they do need to remove and reinstall one sensor.
DSIre is offline   Reply With Quote
Old August 18th, 2017, 06:19   #512
Raydeohed_1
Has anyone been able to make their dealer appointments for modification through the VW claims portal? My portal is still stuck on that last step claiming "once there is an approved fix for your TDI you will be able to make an appointment here" Well the fix has been approved so it seems I should be able to make the appt.
It sounds like ppl are just contacting their dealers directly. Have you had any issues with your restitution money without going through the portal?
Raydeohed_1 is offline   Reply With Quote
Old August 18th, 2017, 06:57   #513
beetlemania
yeah the portal is done with you, dont look at it. You should have gotten an email. At this point you can call the dealer and just ask if your car (have VIN read) is in their system yet to be fixed. BUT you need to fix your email or whatever cause that is how you will be notified by Chase bank to set up the wire transfer for the payment.
beetlemania is offline   Reply With Quote
Old August 18th, 2017, 09:28   #514
meerschm
meerschm's Avatar
Fuel Economy: twice what my chevy used to get
I, too had the web site still say a fix is not yet approved, so I called the dealer.
When I dropped the car off, I had to speak on the phone while at the dealer to a person who verified my contact e-mail via phone, and wanted me to say I understood that the fix means no sell back.
(I turned in the loaner and got a ride home since we are headed out for the weekend. dropped the car off Tuesday morning at 7:30, and it still is not quite done. hopefully a few more days lets them get it finished. I did take a peak, and it caught a glimpse of the new pressure sensors and DPF. thermal blankets for the pressure sensor looks a little better than the foil tape I put on after changing out the pressure sensor.)
Now that I think about it, I will have to double check the connection on that sensor, I had snapped part of the electric connector and put a couple zip ties to keep it in place.
Mike
Free advice: it is worth what you pay for it. (sometimes)
meerschm is online now   Reply With Quote
Old August 18th, 2017, 14:27   #515
jerryfreak
what is the new emissions system warranty on the 2009-2014 cars and does it include turbo and fuel pump like the 15s?
jerryfreak is offline   Reply With Quote
Old August 18th, 2017, 14:55   #516
forrest resto`s
Fuel Economy: best..47mpg over a 2000 mile trip
from what I have read..yes..same as the 15's
forrest resto`s is offline   Reply With Quote
Old August 18th, 2017, 14:56   #517
meerschm
meerschm's Avatar
48 k miles or 48 months on engine, emissions, fuel, pumps.....
the manual cars get another six months or so
Mike
Old August 18th, 2017, 23:28   #518
jerryfreak
that doesnt sound right
pretty sure that pursuant to the settlement they are legally mandated to warrant the emissions system for the "life of the car" which they consider to be 11 years
Old August 19th, 2017, 01:05   #519
craigldavis
TDI(s): 2009 JSW M/T
Depends on your mileage at the time of the fix:
Manual trans:
https://www.vwdiesellookup.com/pdf/V...nual_Final.pdf
And
Automatic trans:
https://www.vwdiesellookup.com/pdf/V...atic_Final.pdf
'09 Jetta SportWagen TDI MT6
280,000 miles
craigldavis is offline   Reply With Quote
Old August 19th, 2017, 03:45   #520
DanB36
That's not correct; there's nothing in there about "life of the car." The warranty mandated by the settlement is 10/120k from new, or 4/48k from fix, whichever is longer.
"DanB36 seems to be always on point." - CT_White_SRT
Sold: 2000 Jetta GLS TDI, Atlantic Blue, 270k miles
Sold to Dieselgate: 2 x 2013 JSW DSG, 1 x 2013 Jetta Sedan DSG
DanB36 is offline   Reply With Quote
Old August 19th, 2017, 04:15   #521
turbobrick240
turbobrick240's Avatar
Manual trans:
And
Automatic trans:
Mileage at the time of fix isn't the only determining factor. An '09 manual trans. Jetta with 950,000 miles still gets 4.5 years or 54k miles of warranty coverage from the date/mileage the fix is applied. Whichever comes first.
Old August 19th, 2017, 19:51   #522
craigldavis
Exactly why I posted the VW link with the full definition so he could read the original in full.
But I should have said depending on the mileage and age to be more precise.
280,000 miles
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
Req'd fix for Gen 1 r11 Dieselgate - VW Group Emission Scandal 27 August 18th, 2017 20:32
Req'd fix for Gen 2 r11 Dieselgate - VW Group Emission Scandal 24 June 16th, 2017 05:57
So, will there be a Gen 3 fix? Tri0de Dieselgate - VW Group Emission Scandal 14 July 22nd, 2016 13:12
Req'd fix for Gen 3 r11 Dieselgate - VW Group Emission Scandal 3 July 13th, 2016 14:28
6th gen and 5th gen production. bignik TDI 101 1 August 25th, 2009 21:52
Page generated in 0.15747 seconds with 12 queries
[Output: 117.17 Kb. compressed to 99.53 Kb. by saving 17.65 Kb. (15.06%)]
