Ok, scoured the A4 damos in winols and found the 2 switches that turn into MAP based smoke limiter. I also found the boost correction temperature map settings... it tells the smokemap by MAP when the air is "less" due to heat or more due to cold. Those numbers you see below explain it.
Manual MAF to MAP smoke limiter
Maf setting
05AD60: 03 0C 00 00 00 01 01 00 01 01 01
00 00 00 01 01
Map setting
01 01 00 01 01
Your address may vary.
In Vagedcsuite, open your file, Click view file in hex. Click search, click hex. Type in 01 01 00 01 01 01 00 00. You will find it 3 times (manual, auto, auto). Those last two 00's should be changed to 01 01 if you want to do MAP based smoke limiter. Do it for all 3 to be sure, unless you know exactly the offset of your maps.
Hit save on top, hit verify checksum on top of vagedcsuite.
Then edit the smoke limiter by MAP:
Manual IQ by map (VAGsuite shows it in the unknown maps.
Example, smoke map manual is address 5c9ec (279372 in decimal mode)- this is at 5cd50 (380240 in decimal) for my ECU. You will see that it is filled in with 5000 or 5500, its IQx1000 for the values... and the top is pressure, side is rpm. You can change those values.
Also the boost correction by temperature should be adjusted if you want IAT to regulate fueling (hotter air is less dense!).
You can copy my map, I got the values from a PD that used map limiter- it calculates correctly (I double checked the values with an online calc), and they use 50C as a center point. Make sure you change the temperature axis and pressure first, hit save, read, before putting in these values!
Here's my maps... it's set for around 16.5-17.5 afr, but 51 mg on my tune turns out to be more like 75 or so... so its around 1.4-1.5 x off... if you are running different nozzles, you should tune it for WOT smokefree, then scale back the other values- maybe a little less iq if you want more afr for lower end (economy).
In maf logging, I saw that with a proper functioning maf, MAF (mg/s)= 480 x (abs boost in bar). In higher rpm it drops, because its harder to push air in. If you run a less restrictive turbo, it might hold 480mg/s per bar higher up.
