gasoline cam has MUCH smaller base circle, to the point that the lash adjusters are probably going to be almost falling out fo the tappetsYou can sink the valves in the head 1mm....but it takes up the slack of the cam follower. If you do decide to sink the valve into the seat 1mm, also remove 1mm from the top of the valve stem.
