turbocharged798
Hey guys, I currently have a G60/VR6 in my 99.5 and its been slipping with DLC1019's and a DIY 15PSI tune. Some days it holds, other days it slips like mad in 4th and 5th. I think it also might be a bit worn as the engagement point is quite low. At the time I put it in, I bought a used AHU flywheel and put a sachs VR6 disk and PP on it. Thinking its slipping because I didn't resurface the flywheel? I have seen people with way more power then me with these clutches so its baffling me why its slipping.
If I get the disk resurfaced and get the quiet 1Z/AHU clutch setup(to get rid of the annoying rattle), you guys think it would hold then? Rockauto has the clutch kit for around $150 and I have a local machine shop that can clean up the flywheel.
I also was looking at the LUK 17-050 DMF kit but I really hate DMFs. The thing is the price is right and if it can hold the power I would consider it.
Thanks in advance.
Thanks in advance.
