mastoidbone
- Joined
- Jan 20, 2005
- TDI
- passat05black
I had 10,000 mile change and invoice says they put in zvw-352-540-s engine oil in....is this ok??is it 505 01???
Thank you
Thank you
You should probably get that oil out of your car asap. VWRobert51 posted a thread here a few months back about a PD he was aware of where the engine had issues with use of non 501.01 oil. You might want to do as he said and scream bloody murder about your engine, ask them for a replacement and see what they say. If there are any issues, it will probably make itself known as you put more miles on the car.mastoidbone said:Thanks a bunch I will call them monday.....I've driven 2000 miles since...did I do the engine any real damage?
No. That part number = Castrol Syntec 5W-40, with VW 502.00 and 505.00, not VW 505.01.mastoidbone said:I had 10,000 mile change and invoice says they put in zvw-352-540-s engine oil in....is this ok??is it 505 01???
