Old November 18th, 2013, 10:05   #1
vincedeon
TDI(s): 2006 Jetta
Default 06 BRM starting issues, surging, stalling
Warning: wall of text - looking for where to start on this problem. The local garage hasn't been able to nail it down yet. Feels to me like an intermittent electrical fault.
Our once-reliable Jetta has started giving us issues that we are having trouble nailing down. I've run Vag-com a few times but nothing definitive seems to be showing up. The vehicle is a 2006 BRM w/DSG and no mods.
Recent history: May 2012 260km replaced camshaft owing to worn lobes. August 2012 272km replaced Turbo as it was full of gunk (thanks to lobe#3 and the camshaft).
At 291km on July 24 2013 vag-com showed problems in 01-Engine, 02-Auto Trans, 03-ABS, 44-Steering Assist with malfunctions (along with others unrelated like a bad speaker. At this time the engine would stall after starting, under load (acceleration, up hills) would seem to skip and surge with power.
01: Engine
001618 sensor reference voltage B
P0652 - 000 - too low - intermittent
02: Auto Trans
18256 DTC memory of Engine Controller
P1848 -000 - intermittent
03: ABS brakes
01314 - engine control module
013- check DTC memory -intermittent
44: steering assist
01314 -engine control module
013 - check dtc memory
Between then and the past month the power skips and surges were minimal without rhyme or reason as to when they'd appear.
In the past month (around 295km) it is hard to start sometimes (warm or cold weather) and other days is fine. Hard to start days means that it won't stay running long either. Power skips and surges are much more noticeable too. It has seemingly stalled coming up hills on highways with the Traction control, low oil pressure and glow plug light coming on and flashing along with the tachometer failing, but the engine keeps running. I pull off to the side and restart the car to clear these alarms.
Here's the edited log after the latest event with sections removed that contained no errors:
Sunday,17,November,2013,15:55:33:55100
VCDS Version: Release 11.11.6 (x64)
Data version: 20121223
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWST31K56M662435 Mileage: 295210km/183434miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H01--- Serial number: VWZ7Z0E2538041
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 64E963A3A78C8338A43
3 Faults Found:
000801 - Engine Speed Sensor (G28)
P0321 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 10
Mileage: 294990 km
Time Indication: 0
Date: 2000.00.00
Time: 14:40:15
Freeze Frame:
RPM: 2436 /min
Speed: 112.0 km/h
Load: 56.1 %
Voltage: 14.52 V
Bin. Bits: 00001000
Idle Stabilization: 0.0∞KW
RPM: 1197 /min
009572 - Turbocharger Boost Control Position Sensor Circuit
P2564 - 000 - Signal too Low - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 295013 km
Time Indication: 0
Date: 2000.00.00
Time: 22:11:06
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Lambda: -9.2 %
Absolute Pres.: 969.0 mbar
Absolute Pres.: 183.6 mbar
Duty Cycle: 101.6 %
001618 - Sensor Reference Voltage B
P0652 - 000 - Too Low - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Bin. Bits: 00100000
Bin. Bits: 00000000
Bin. Bits: 00100000
Bin. Bits: 00100000
Bin. Bits: 00100000
Readiness: 0 2 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 042 H HW: 02E 927 770 AD
Component: GSG DSG 070 0913
Revision: 00007000 Serial number: 00000505100482
Coding: 0000020
VCID: 181107532B4497D8F8B
1 Fault Found:
18256 - Please check DTC Memory of Engine Controller
P1848 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Reset counter: 1
Mileage: 295206 km
Time Indication: 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3FA38CCF6EAA80E0191
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000142824
Coding: 10018E234004180000140000001400000008730B5C
Shop #: WSC 93140 999 53632
VCID: 2A75CD9B852815485EF
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0402
Coding: 00065493
Shop #: WSC 93140
1 Fault Found:
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 5
Reset counter: 78
Mileage: 295013 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.05 V
ON
ON
OFF
OFF
OFF
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 852 D
Component: KOMBIINSTRUMENT 3HL 1212
Coding: 0023307
Shop #: WSC 93246 999 04876
1 Fault Found:
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 364DE9EB419041A8CA7
1 Fault Found:
00100 - Drivers Interior Locking Button (E308)
**** I have a button that works when it feels like it ****
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
Shop #: WSC 00000 000 00000
VCID: 3245D5FBADF85D88E6F
1 Fault Found:
004 - No Signal/Communication - Intermittent
Freeze Frame:
Mileage: 4960 km
Temperature: 22.0∞C
Voltage: 14.50 V
Voltage: 14.30 V
End ---------------------------------------------------------------------
I appreciate any input that can be offered here.
thanks,
.Vince
2006 Jetta TDI Sedan
1988 Ford F350 7.3L IDI Turbo Diesel 5sp
Licensed Radio Amateur VE6LK/3 es VE3LKV
vincedeon is offline   Reply With Quote
Old November 18th, 2013, 10:39   #2
D-Cell_Mekanick
Fuel Economy: 45ish
Inspect the engine wiring harness for chaffed wires inside the plastic loom. Been many of us that have had to replace this harness for various reasons, one being hard starts.
2014 Passat SEL TDI(GONE BUT NOT FORGOTTEN). Tungsten Silver exterior with Titan Black interior. I have VCDS HEX-USB+CAN, still learning how to use it.
D-Cell_Mekanick is offline   Reply With Quote
Old November 18th, 2013, 11:39   #3
muhibmc
sounds like wiring harness...
check the large loom of wires, running across the front of the engine and transmission. (you will have to remove the air box to see it)
muhibmc is offline   Reply With Quote
Old November 21st, 2013, 22:03   #4
vincedeon
TDI(s): 2006 Jetta
Yep, found a couple of small wires on the outside of the harness that were chafed right at the same spot. Corroded up a few inches from there, too. A solder splice and wrapping the whole harness in 3M 700 electrical tape cured it.
Thanks to Bob and this thread http://forums.tdiclub.com/showthread.php?t=239987
06 Jetta TDI Starting Issues sbkins00 VW MKV-A5 Golf/Jettas 7 September 28th, 2013 04:20
2006 BRM with a couple issues, hiccups and stalling SuperJ VW MKV-A5 Golf/Jettas 5 March 18th, 2013 17:57
06 Jetta brm with a dsg not starting:( sledspeedr8cer TDI 101 7 December 1st, 2012 09:37
06 Jetta Not Starting/Stalling Problem KimmysTDI VW MKV-A5 Golf/Jettas 4 July 19th, 2011 19:40
Intermittent Starting & Stalling Issues ronnieg VW MKIV-A4 TDIs (VE and PD) 0 December 3rd, 2007 11:17
Page generated in 0.14188 seconds with 11 queries
[Output: 73.17 Kb. compressed to 66.42 Kb. by saving 6.75 Kb. (9.23%)]
