Old November 1st, 2010, 10:36   #1
richard hamilton
TDI(s): passat
Default timing belt breaking data?
I apologize if this is already on the forum, but I can't find it. I am just curious if there is a thread for actual data on timing belts breaking. What mileages (and other information) are belts actually breaking?
richard hamilton is offline   Reply With Quote
Old November 1st, 2010, 10:44   #2
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
What motor? And no, not really. It's exceedingly rare for it to happen early. Often its the result of something else breaking first.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old November 1st, 2010, 10:49   #3
jettawreck
jettawreck's Avatar
With a bit of research(ing) you will most likely prove to yourself that the TB itself is usually not the first component in the system to fail (break, shred, etc). Often one of the rollers, the tensioner, or waterpump are first to give out, which destroys the belt. This is why its so important to change all the components in the TB path, unless you like to gamble.
The '03 that I bought (broken TB, torn all apart in boxes) was driven to 165,005 miles (IIRC) on the original TB/components. The tensioner looked suspect to me, but prior owner took it somewhere that tore it apart and left all the parts boxed. The TB indeed broke, but the tensioner gave out and let the belt go slack, stripped off a bunch of teeth, then got caught in something and snapped. Nothing that spins goes forever.
Change it all at the scheduled interval and you will be fine. Go longer and maybe/maybe not.
2004 Cadillac SLS (wife's)
Old November 1st, 2010, 11:04   #4
TDICADDGUY
TDICADDGUY's Avatar
Fuel Economy: 42/46/51 with 5 speed - was 36/40/42 with 01M
I can only assume that the reason you are asking this is because you either already are (or want to) go over the recommended interval. This is playing russian roulette with your engine. There is no way to know when the belt (or any of the related components) will fail. It could happen 50000 miles after the interval, or 500.
Unless you like the idea of having to spend thousands to fix your engine, it would be best to have it done right and on-time.
2012 BMW X5 35D 2000 NB with 3 pedal mod, RC3, PP520's, Eurojet SMIC, SBC 3, 2.5" side exit straight pipe, 2" lift.
TDICADDGUY is offline   Reply With Quote
Old November 1st, 2010, 11:25   #5
Rattler05.5
Fuel Economy: 37.5 mixed; 44 Hwy
Originally Posted by jettawreck View Post
165,005 miles
Aha! Proof that you can drive to 165,004 miles before replaceing it!
Realistically VW looked at the data and factored in some cushion so that they weren't failing under the recomended interval. The longer you go the odds of it failing get higher and higher. The odds of it failing at 80k or whatever they recomend are so low that they said it was statistically an improbablility.
The risk is yours and the car is yours and it's your money. Drive it till it breaks and let us know how long NOT to go.
Rattler05.5 is offline   Reply With Quote
Old November 1st, 2010, 11:43   #6
richard hamilton
TDI(s): passat
My 2004 passat tdi has about 80,000 miles now, and of course the dealer wants me to do the timing belt now. The book says 100,000, so that's why I am asking.
Old November 1st, 2010, 11:55   #7
Tom_B
I don't think you will find the data you're looking for. You may know VW reduced the recommendation from 100k to 80k on your car not that long ago.
Given your join date, I assume you know about the balance shaft module issue. If not, please educate yourself (B5 forum) prior to having the timing belt work done since there are cost savings to performing several repair/maintenance issues at the timing belt change interval. Good luck.
14 Touareg TDI; 14 A6 TDI
No longer in the driveway: 03 NB TDI, 04 Jetta GL TDI, 05 Passat GLS TDI, 09 Touareg Lux TDI
Tom_B is offline   Reply With Quote
Old November 1st, 2010, 12:04   #8
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 3.3 Mi/kWh
Someone I knew drove 130,000 miles on their 00 Beetle's 60k belt. It sheered of 19 teeth.
They had just gotten the car, and according to the seller the belt had been done at 100k
-J
Present:
2018 Tesla Model 3 DM. 47,000 miles.
2014 Cadillac ELR. 38,000 miles.
2013 Fiat 500e. 28,000 miles.
Past:
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG. Sold to JDSwann's Brother.
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old November 1st, 2010, 12:05   #9
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
Absolutely. In fact the only one that comes to mind is this one: http://forums.tdiclub.com/showthread.php?t=253995
- Nick -
02 Jetta TDI 340k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old November 1st, 2010, 12:30   #10
sohccammer427
sohccammer427's Avatar
Fuel Economy: ?~45~?
Does this hold true for an '06 Jetta PD? My owners manual specifies 100k miles as the interval. I have not received any smail or email from VW or the dealer stateing it has been lowered to 80k miles.
2015 Passat TDi SE 6 Speed Manual
2017 Chevy Colorado Duramax
sohccammer427 is offline   Reply With Quote
Old November 1st, 2010, 13:18   #11
volmaniac
volmaniac's Avatar
TDI(s): 02 Golf GLS
Fuel Economy: around 50 mpg
You should consider these folks before the dealer:
Colorado
Steve Carroll - username SCarroll
Aurora, Co
Frey's Foreign Car Service
2550 49th St
Boulder, CO 80301
(303) 440-0725
European Performance Specialist
406 S. Sierra Madre St
Colorado Springs, CO 80903
(719) 475-1046, Loren
aNut
Denver
http://www.dieselland.net/
Hardey's Motorwerks
10315 South Progress Way Unit 2
Parker CO, 80134-4020
Phone: 303.840.7664
http://www.hardeysmotorwerks.com
Cattle Creek V Dubs
5405 County Road 154, Unit L
Glenwood Springs, CO 81601-8626
Phone: (866) 434-6625
www.cattlecreek-vdubs.com
http://forums.tdiclub.com/member.php?u=77903
German Motorsports
Kirk (owner)
632-0664
http://forums.tdiclub.com/showpost.p...postcount=1007
Metrick Methodz
3827 Glenarbor Ln
Fort Collins, CO 80524 - 6459
(970) 482-8672
2002 gls golf
Originally Posted by foxracer1 View Post
Wars are fought over religion, money, land, and brand of injectors for a TDI
volmaniac is offline   Reply With Quote
Old November 1st, 2010, 13:21   #12
jasonTDI
jasonTDI's Avatar
Yes, but honestly all my clients are still going 100K without issue.
Old November 1st, 2010, 13:30   #13
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
You needn't worry about the belt on the Passat, it is the CHAIN you need be concerned with. And no, your dealer won't have a clue.
oilhammer
www.cardocautomotive.com
Old November 1st, 2010, 13:32   #14
Drivbiwire
Zehntes Jahr der Veteran
100K absolutely on the PD engine (2006 for you newbies).
Its a very good design and stronger than a chain. As mentioned, the weak link is the water pump. As long as you replace the water pump and rollers at 100K along with the G12 coolant (70/30 ratio) you will NEVER have a failure of the belt.
Also, make sure all the related hardware is replaced since VW uses coated TTY bolts (single use).
Specializing in Injectors for CRI, CR, PD, VE, IDI VW, Audi, MB, SEAT and Skoda Diesel engines.
Offical Importer, Distributor and Installer for Fratelli Bosio, S.R.L. North America
Quotes and Pricing for TDI Injectors
Old November 1st, 2010, 15:14   #15
n1das
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Exclamation
Mine failed last summer at 76k miles and gave no warning whatsoever. This was in my 05 PD JWagen (BEW PD engine).
At first glance, the TB didn't look broken:
Upon closer inspection, you can see what failed:
Close look at the carnage:
I only put average miles on this car compared to my logging ~ 1k mile/week in my 02 Golf. After 4 years I suspect I was bumping up against the time limit for that belt. Back in 2005, the future of TDIs in the USA was up in the air and I hedged my bet on future availability by grabbing the 05 PD JWagen while I could in case there were no more new TDIs after 2006. I kept this car in pristine showroom condition and also didn't drive it in the winter. Atrophe from non-use may have factored into the belt failure as well as age.
I could have fixed the failure for a lot less than dropping a new engine in there but I wanted to do previously planned performance upgrades while everything was apart. Hardware was bone stock at the time and the clutch was beginning to slip with RC2 tuning. It was known upfront that a clutch upgrade would be needed and it was planned for. A turbo upgrade was also planned for it to solve a boost creep issue with the stock (KP39) turbo and tuning. Given the rest of the car was in like new condition, I decided to make it all new again. Chris Hill (TDIclub mrchill) did the engine swap and upgrade work. The whole job was expensive but the car is SOOOO much better than new now.
My engine swap and upgrade thread:
http://forums.tdiclub.com/showthread...&highlight=atd
Why DIESEL is better: (Courtesy TDIclub forum member wxman)
PM - https://sites.google.com/view/lmarzccm/home
Air Toxics - https://sites.google.com/view/loren-marz-ccm/home
Ozone Precursors - https://sites.google.com/view/lorenmarz-ccm/home
General - https://sites.google.com/view/emissions-general/home
n1das is offline   Reply With Quote
Page generated in 0.19122 seconds with 10 queries
[Output: 140.59 Kb. compressed to 118.11 Kb. by saving 22.49 Kb. (15.99%)]
