Old February 18th, 2010, 11:43   #1
Pcar993
Default Fuel filter looks white inside when i look thru the return fuel hole. Is my filter ok
Fuel filter looks white inside when I look thru the return fuel hole tee on top of the fuel filter. Does that mean my fuel filter is clean?? Should i change it still? It looks pretty damn clean inside. I just bought my Jetta TDI 2 weeks ago so im not sure when she changed it the last time.
My Golf 2000 TDI 180whp 328wtrq (With VNT17) I'm now running vnt17/22, no dyno on that yet.
Jetta 2001 TDI, Was converted to burn WVO, but not anymore. 47mpg with an auto!
AKA "Diesel Power" on VWvortex
Pcar993 is offline   Reply With Quote
Old February 18th, 2010, 12:25   #2
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
It is white inside when new. Don't go by the looks though, change it when the schedule says so.
- Nick -
02 Jetta TDI 340k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old February 18th, 2010, 12:41   #3
dieselfuel
If it were my car, I'd go ahead and change it for peace of mind.
The last fuel filter I changed looked good and I thought I'd hang onto it. However, the car had more power with the new filter, so I pitched the old one into the trash.
Again, if it were mine, I'd replace the air, fuel, and oil and oil filters. Now you know they're new.
df
dieselfuel is offline   Reply With Quote
Old February 18th, 2010, 13:29   #4
Pcar993
df
how about ATF fluid? Car has 139k I think she mentioned that she did change the ATF fluid once. I will need to verify that.
Im changing my fuel filter as we speak.
Old February 18th, 2010, 13:33   #5
greengeeker
Does she have any records where, what, when on the ATF change? IF you have red fluid in there, yes get it flushed asap.
- Nick -
Old February 18th, 2010, 15:32   #6
dieselfuel
I have a 5 spd man trans.
But yes, I'd change the fluid, too, if it were mine.
Do it all at once, for peace of mind.
Page generated in 0.15935 seconds with 10 queries
[Output: 71.81 Kb. compressed to 62.60 Kb. by saving 9.21 Kb. (12.82%)]
