Old May 10th, 2007, 23:26   #1
CentralOregon
CentralOregon's Avatar
Default ARP Headstud kit for the A3?
Do they make one, who sells it and what is the part number?
Anyone have success or problem stories to go along with this upgrade or recomendations of parts I should upgrade in parallel with the studs?
Thanks,
B
CentralOregon is offline   Reply With Quote
Old May 11th, 2007, 07:14   #2
hgeittmann
hgeittmann's Avatar
The ARP thread has a link to what to buy. The same kit works for 1Z/AHU/ALH engines.
B5 wagon
hgeittmann is offline   Reply With Quote
Old May 11th, 2007, 22:48   #3
CentralOregon
Default That thread is where I started.
So do I get the ARP-204-5402 kit? I don't see anything sorted by 1Z/AHU/ALH or listed to specificly fit these engine types? Here is the VW selection at Summit Racing.
Old May 11th, 2007, 23:21   #4
dieseleux
Théoricien -TDIClub Contributor
dieseleux's Avatar
TDI(s): Jetta TDI 02
Fuel Economy: 4.2L/100km
I use ARP bolt on my TDI98 (AHU).
No problem, run at 22psi with K03 hybride turbo (K03/K04).
ARP part number: 251-4701 (ford:Cosworth/sierra/escort)
Dieseleux
Si votre seul outil est un marteau, toute les solution ressemble à des clou.
If your only tool is a hammer, all the solution looks like nail.
dieseleux is offline   Reply With Quote
Old May 12th, 2007, 12:49   #5
onlyn8v
Dieseleux
Same here.. Using the above p/n
Dave
90 Turbo Corrado (Red) 034EFI, 3" exhaust, body kit, Built ABA + lots more
98 Jetta TDI 5 speed 249k+ (Red) RC3+, Ventectomy, tint, leather interior, Porsche wheels, DRL-less, ported / polished head with matched intake manifold,3" catless exhaust, 2.5" downpipe, PP520, hybrid turbo, FMIC, smoked e-codes, badgeless grille, H&R cup kit
04 Jeep Wrangler 4.0 33K Blue 4" Fabtech lift, MT wheels, 33",Borla, sliders, snorkle, 15mpg
...Other crap Im parting
onlyn8v is offline   Reply With Quote
Old May 12th, 2007, 18:14   #6
2footbraker
2footbraker's Avatar
I think it is the same p/n for all VW A1 to A5. I am getting the Ford Cosworth set for my A2.
2006 Jetta TDI - Malone Tuning stage 4, G60/VR6, Vogtland 55mm/Koni Sports, Darkside GTB1749V, EGR delete, Frank's BRM cam, etc.
Several other IDI's and TDI's
2footbraker is offline   Reply With Quote
Old May 12th, 2007, 21:31   #7
CentralOregon
Default Head Gasket Replacment Required?
Can I just swap out the bolts or do I need to replace the head gasket when doing this?
Old May 12th, 2007, 21:46   #8
dieseleux
dieseleux's Avatar
Just swap out one by one, i do this on my engine.
Torq in five step, search for directive on this forum.
Dieseleux
Page generated in 0.15338 seconds with 10 queries
[Output: 83.16 Kb. compressed to 70.87 Kb. by saving 12.29 Kb. (14.78%)]
