arne487
I'm not terribly familiar with the oil plumbing on my ALH. I've seen gauges tapped into the stock pressure switch location using something like this. I don't have much room there because of my bypass filter.
Is there any downside to putting the same sort of adapter into the port on the back of the filter housing where the turbo oil feed line attaches? I have a braided steel line there, so it should fit with no issues as long as the threads are the same (are they?). Will the pressures and temps there be the same ones I should be looking at?
Also, what pressures and temps should I start to get concerned at? What ranges are people using on their gauge faces?
