Old October 9th, 2019, 16:14   #1
RedNATEr
TDI(s): 2013 JSW TDI
Default Seat Recline & Seat Heater not working 2013 JSW TDI
Hello, new tdiclub forum member here from the DFW area. Recently purchased a 2013 JSW TDI that sat for 3 years according to the carfax.
The only issue I'm having is that the seat recline switch and seat heater on the drivers side doesn't work. The passenger side seems to work fine. The seat is reclined a bit too far and it makes driving a bit uncomfortable.
I posted this on /r/tdi and a user there mentioned that I should check and re-check fuses, so I bought a test light and all fuses on the left side of the dash and under the hood seem to be working as expected.
I can't seem to find a decent fuse map that may tell me where the fuse for this is. I found some old tdiclub posts with old fuse panel images, but all the fuses seem to be OK. I think there may be another area under the dash with the seat fuses, but I can't seem to find the exact area to see if that's actually the case or not.
I did notice some green/blue flaky corrosion when I move the seat all the way back and remove the little flap of carpet where the electrical connections for the seat are. I've removed all the connections and sprayed contact cleaner there but that hasn't seemed to help. Maybe a previous owner spilled a drink or something? I see no signs of corrosion anywhere else on the car that I can tell.
I did ask the dealer about this but they want $300 just to diagnose it, which I may eventually do. I'm pretty handy, just new to electrical issues, so I thought I'd seek out advice on this before I take it in.
Thanks for any advice
redNATEr - 2013 Blue JSW TDI - 25k miles
RedNATEr is offline   Reply With Quote
Old October 10th, 2019, 13:57   #2
Joe Romas
Fuel Economy: 48.1 mpg bringing it home
Almost everything works off of "modules" on these cars but I just looked at a VCDS printout showing the information of the modules in my new to me 2014 TDI JSW and any errors that maybe store. But I don't see anything specific to your seat problem but the heated seats may be part of the dashboard.
Since you have found corroded connectors you maybe on the right track and it may have leached up the wire(s). Here's information on the VW specific diagnostic tester from Ross Tech. If you do your own work it maybe worth it to you. https://www.ross-tech.com/
Joe
Joe Romas is offline   Reply With Quote
Old October 18th, 2019, 08:04   #3
Asheagle
Asheagle's Avatar
TDI(s): 2012 JSW TDI
Default 2012 JSW TDI front driver seat lean adjustment and heater
I have the same issue on a 2012 JSW TDI I just purchased. The front driver seat lean adjustment (electronic) and heater do not work. Any help would be greatly appreciated!
Asheagle is offline   Reply With Quote
Old October 18th, 2019, 14:12   #4
RedNATEr
I haven't figured it out quite yet. I did take some jumper cables tied to alligator clips, removed the connector behind the tilt switch, and supplied 12 volts to the pins of the cable and the motor did move, so I at least know the motor is OK. I just don't think I'm getting power to the switch. I actually just used that method to get the seat adjusted exactly where I need it and it's since been more comfortable to drive, but I would like to get the seat heaters working before it gets really cold outside.
I got a cheap harbor freight test light and verified that every single fuse is good. So either the fuse is missing, or it's in a different location somehow.
Old October 24th, 2019, 16:16   #5
Asheagle
Asheagle's Avatar
Default Found issue with mine, working on fix.
I decided to remove my seat so I could get a better look underneath and test the heating elements for pass through voltage. The elements passed but when I disconnected the seat wiring harness from under the carpet I noticed the same green/blue white flaky corrosion as mentioned above. Inspecting the harness cable I found 3 wires that were totally unattached from corrosion.
Does anyone know how to disassemble the wiring harness connector? Or do I need to purchase a new one?
Old October 24th, 2019, 20:41   #6
Asheagle
Asheagle's Avatar
The heated seats are working now, on both sides. The short on the drivers side must have shut down both sides?
Old October 28th, 2019, 08:10   #7
RedNATEr
So what did you do to get them working? Clean off the corrosion somehow?
I bought a Carista bluetooth OBDII connector and found I have 3 codes related to the seat heaters - 9479698, 9479699 & 02092
Also, we had a big rain storm and I think either my windshield and/or my sunroof is leaking into the floorboards so maybe that's what caused the corrosion in the first place - not sure.
Old October 31st, 2019, 15:05   #8
Asheagle
Asheagle's Avatar
I bought and 8 port connector and rewired all the wires to the new connector. I also had codes to the seat heaters, 3 of my wires were completely broken through.
All Passenger Locks, Driver Seat Tilt, & Heated Seats Not Working. Related? 2009 JSW Geo VW MKV-A5 Golf/Jettas 5 August 17th, 2016 14:27
Seat Heater not working smcgill11 TDI 101 3 July 28th, 2014 20:04
Seat tear front seat 2013 jsw Tdi leatherette Brent Wahl VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 11 January 17th, 2014 15:35
New seat heater not working? 2005TDI_1994IDI VW MKIV-A4 TDIs (VE and PD) 9 December 12th, 2013 06:52
One seat heater not working ?? help Monkey1 TDI 101 7 December 7th, 2007 12:34
Page generated in 0.14471 seconds with 11 queries
[Output: 87.25 Kb. compressed to 75.28 Kb. by saving 11.97 Kb. (13.72%)]
