unorganizedplan
These both lock into the OEM housing?Stant 45379
Gates 33209
The above two I have used with no problems.
These are warmer than OEM? Do you tend to have better luck with one or the other (or OEM)?
Gates 33209
Ok gotcha, maybe I'll leave it be unless I need to get into the cooling system for TB change or frostheater install, and just do one big drain and refill of coolant while performing the other work.OEM replacements seem to work best. If the 'stat is working correctly I'd leave it be.
They're both listed as 195F/90CThese both lock into the OEM housing?
In the past six months, I've received TWO OEM thermostats from my local dealer (about four months apart), which refused to open at the proper 87C; both were stamped "87C".Highly recommended! Like everyone says:
1. use genuine parts,
2. clip new thermostat into new housing with new o-ring
3. have no regrets.
