Make sure you have a 32mm socket handy to remove the cap from the filter housing.
First you use a 13mm to remove the drain plug in the cap, then put it back and use the 32mm to remove the cap.
I did it this past weekend and forgot to bring my 32mm socket with me. We were changing the oil at another location, not at home. Man, that sucked. I ended up changing the oil, then later at home had to get underneath again and change the filter. It was a right kerfuffle.
In the future, I'm going to change the filter FIRST, and THEN drain the pan. It's much nicer to have the filter cartridge go plop, into an empty drain pan, instead of a full one, which results in oil splashing everywhere. I mean, that didn't happen to me, because I used two pans, but I'll use one pan next time. Less cleanup.
All the screws that hold the bottom cover on had the threads stripped off of them. They must use the absolute cheapest fasteners they can find for that. I replaced them with stainless #10 pan-head sheet metal screws and washers. 3/4" long. Those should last forever. You need 8 of them if you feel like buying those in advance. Cost a couple bucks.
